Scorpion.jpgIMG00134-20111017-0532[1].jpgIMG00135-20111017-0532[1].jpgHi all,
I've been working on this build with the guidance of Jesse J. and have built on his recommendation(should I be scared).JK
I'm using a 9/16 brass flood chamber tube with a 1/4 brass stuffing tube alonf with a huey .187 flex cable. This has been a fun project and am so excited to to see how she'll perform in P-mono. So far everything is lining up real nice! My issue before I nail everything down is I had to sand the1/4 stuffing tube in order for it to be able to slide into the strut which worked out well.you'll see with the .187 cable in the 1'4 tube doesn't allow for plastic tubing? sorry if I got the terminology mixed up?
will there be any issues with leaving the plastic sleave out or do I need to go with a .150 cable with the plastic insert?IMG00128-20111017-0530[1].jpgIMG00133-20111017-0532[1].jpg
Do you see a problem with the position?
