ML Boatworks PS295 Build (Jedi Masters - No. 8).
  • Jedi Master
    • 242
    ESC is the Aquacraft 60amp type from the UL-1 (motor is from the UL-1 also);
    Added the water cooling tubes and also the batteries. I'm using two PolyRC 4S1P 30c 3000mah packs, which will be connected in parallel to give me 6000mah of run time. They fit great and the steering rods clear them fine;
    Do or do not, there is no try!!!!!
    Aeromarine Titan 29 H&M Hawaii Kai III Proboat Stiletto ML Boatworks PS295 (No.8)
    • F1 madness
      • Feb 2010
      • 788
      Hey jedi looking good,wont be long now
      just 1 thing change the cooling so it goes in at bottom and out at top of motor,more effiecent cooling for the motor this way
      http://s577.photobucket.com/albums/s...79/F1%20boats/
      Daz from sunny England
      • Jedi Master
        • 242
        Cheers. Can you educate me about the motor cooling, I only rigged it that way as I figured it would create less pressure in the cooling system as once the flow reached the top of the motor, it would then have gravity to help draw water up through the system as the water in the motor ran downwards? With less pressure on the system I thought it would allow the water to flow faster and cool better?
        • Jedi Master
          • 242
          Got most of the paint work finished. Still need to add some pin-striping and the rear face of the sponsons are going to be yellow also. Maybe a bit of dark blue for the rear sponsons. The top and sponson stripes are copper, which when first painted, shine like chrome. But, once you add the clear coat it dulls down and looks more like a dark wood;
          And you just gotta have a few sponsor decals....
          • Jedi Master
            • 242
            I have a proper windscreen coming from Monojeff, but until it arrives I've cut one from CF vinyl. It'll do for now...
            Comments welcome......
            • ron1950
              • 3082
              looks great man.....now go hit the pons and dont be shy about turning down your steering travel......mine spun alot till i did that..they dont need much to turn on a dime
              • F1 madness
                • Feb 2010
                • 788
                Hi jedi
                looks sweet
                by going in through the bottom it allows the cooler to fill and cool more of the motor before exiting,also pushes all the air out of the system,it doesnt add much pressure anyway.
                Where you planning on running it?
                • Jedi Master
                  • 242
                  Hi jedi
                  looks sweet
                  Of course, I didn't think about air getting stuck; good call, thanks! When its fnished I expect I'll be over at chasewater sometime. Don't really know of anywhere else that local that I could run it at, although to be honest, I haven't looked that hard!
                  • Jedi Master
                    • 242
                    Will do, thanks for the tip!
                    • F1 madness
                      • Feb 2010
                      • 788
                      cool,will have to try and catch up if you want,let me know when you go and we'll meet up
                      • Jedi Master
                        • 242
                        Sounds good, will do!
                        • mgcrimson
                          • Oct 2010
                          • 54
                          In post #12... what size hardware are the bolts and lock nuts?
                          Looking good!
                          ROLL TIDE ROLL!
                          ML Boatworks PS295, Dumas Hot Shot Sprint 3.5, JAE 21FE, Yellow Jacket Outrigger,
                          • moonlighter112
                            • Feb 2011
                            • 109
                            You need to put 2 wheel collers on each steering rod 1 at each end
                            • Jedi Master
                              • 242
                              Looking good!
                              Thanks. The bolts are 4-40 3/4" size, with hex heads.
                              • Jedi Master
                                • 242
                                Hi, sorry but whats a wheel coller? and why do I need them? Cheers, Jedi.
