MHZ Lizard Xtreme
  • Gerwin Brommer
    • Dec 2008
    • 918
    #61
    Douggie,
    Are you sure about running a 37mm prop on a Lizard ????
    • Flying Scotsman
      Fast Electric Adict!
      • 5190
      #62
      Hi Gerwin
      The Y537/3 was my initial setup prop. I have run Prather 220 and X640 with good results.
      I am a bit of a fan of small diameter props with large pitch
      Douggie
      • Gerwin Brommer
        • Dec 2008
        • 918
        #63
        Small props with large pitch are for SAWhydro's
        For a real breathtaking Lizard : lehner 2250/8 on 6S2P on a X447 Andy Brown.
        • Flying Scotsman
          • 5190
          #64
          No kidding....do you have a spare Lehner 2250/8. I could use...at no cost
          On cats the small prop also works well
          EDIT
          Gerwin, please look at my setup..cheap motor..cheap ESC. and sport useage
          Folks, if you do not know, Gerwin is a very experienced FE boat builder and you can take what he states to the bank
          Douggie
          • bababoboRc
            • Mar 2008
            • 26
            #65
            Hi There my one did 91k on gps with M445
            • Gerwin Brommer
              • Dec 2008
              • 918
              #66
              Bababo :
              Nice !
              Clean boat, very nice setup !
              With the Etti it will work fine.
              6S is the limit for the KB8XL.
              Don't run it on 6s2P.
              It will demagnetize the motor.
              • bababoboRc
                • Mar 2008
                • 26
                #67
                Thanks the etti esc worked fine till i blew the capacitors in it it was the funniest thing i have ever seen doing a full speed pass the explosion blew the lid off my boat that was taped down six feet in the air i managed to bring the boat in but lost my lid in the pond gutted
                just sent the esc back today for warranty not really sure what happened i was only running an X442 prop
                im running Zippy R 21 to 35c 4500mah
                what do you mean by 6s2P
                • Flying Scotsman
                  • 5190
                  #68
                  Adrian, he is referring to the available amperage ..6S1P 4000mah 20C = 80 amps...6S2P 4000mah 20C = 160 amps.
                  I do not know why this would demagnetize the motor if the prop etc. remains the same over a IP setup. Gerwin?
                  Douggie
                  • Gerwin Brommer
                    • Dec 2008
                    • 918
                    #69
                    6S2P means double sixpack.
                    Strange, what happened to your Etti.
                    At full speed the load on the motor/batt/esc should be minimal.
                    • Gerwin Brommer
                      • Dec 2008
                      • 918
                      #70
                      Douggie.
                      The KB8XL on 6S is fine.
                      But this motor turns hot easily.
                      Running the motor for a "very" long period, while it's hot, will
                      destroy it.
                      In Germany are a few guys who modified the motor, added coolingholes
                      in the frontend of the motor. And some of the KB's have spacers/shims inside,
                      they can cause friction on the bearings, which means extra heat. So they removed a shim/installed a smaller spacer.
                      • Flying Scotsman
                        • 5190
                        #71
                        Thanks Gerwin and as he mentions the KB series of motors are not the best built motors without modifications to tame their heat and amperage draw
                        Douggie
                        • bababoboRc
                          • Mar 2008
                          • 26
                          #72
                          Ok i was going to mill some holes in my kb motor too but could not see any point in doing so because the boat is totally sealed
                          and the kb 45 is really something i wanted to trash the hell out of it to see what it could do i'm not even running thrust bearings on it just looking at some neu motors at the moment but still have another Kb to trash first
                          • bababoboRc
                            • Mar 2008
                            • 26
                            #73
                            Hi guys i have tried several times to contact mhz usa & germany and had no reply
                            i'm trying to get a new lid for my lizard xtreme are they having an extended holiday or what ??
                            • Flying Scotsman
                              • 5190
                              #74
                              Adrian, belive me they are slow to answer...the old fashioned telephone works best
                              On another point. What are the members thoughts on small diameter to large pitch. IMO...keep the motor running at its perceived optimum rpm to load?? High voltage...low KV large can motors. Keep the prop spinning with the least amperage requirement Or do I have it wrong?
                              Douggie
                              • cacofonix
                                • 240
                                #75
                                hi folks
                                i'm mounting a Lizard , congratulation for your clean mounting.
                                just wondering about CG.
                                on pictures i can see that motor is 15 cm from the back , right ??
                                my setup :
                                Feigao 12XL (thanck steven)
                                6S1P 5000 25C
                                Turnigy 180A
                                prop ........... i'm not sure 45 or 48 or ......more ??
                                thanks for your help
                                H
