MHZ Lizard Xtreme
  • SJFE
    • 4867
    #31
    Got it...Getting it...Thanking you for it
    • goldendesign04
      • 210
      #32
      douggie,
      as I usually see from one such as your self, clean an profesional.
      I like it a lot, good work.
      -Wayne
      • Flying Scotsman
        Fast Electric Adict!
        • 5195
        #33
        Finished MHZ Xtreme Lizard
        Thanks Wayne.
        Finished Hull
        Speedmaster hardware, 11XL Feaigo, Sentilon HV 100 esc, 1 5000 TP 3S and 1 5000 TP 2S in series, Y537/3 prop, Hitec HS 645MG servo.
        • Steakhouse
          • Dec 2007
          • 128
          #34
          Originally posted by Flying Scotsman View Post
          Thanks Wayne.
          Finished Hull
          Speedmaster hardware, 11XL Feaigo, Sentilon HV 100 esc, 1 5000 TP 3S and 1 5000 TP 2S in series, Y537 prop, Hitec HS 645MG servo.
          Very clean setup. Nice!
          • bababoboRc
            • Mar 2008
            • 26
            #35
            MHZ Lizard
            Hi There Flying Scotsman i love your boat
            i'm setting up the same hull and similar setup, and speed controller
            but i have this motor Turnigy BL 36-56-2700 running on 6S Lithium, is this powerplant too small for this size hull ?
            and what size rudder and surface drive are you running
            Regards
            Adrian
            • Flying Scotsman
              • 5195
              #36
              I am not familliar with that motor and It looks like a small can. I presume 2700kv. If that is the case WAY TOO HOT with 6S . What prop ?
              The hardware is Speedmaster as previously noted. Please note I am borderline on my setup
              Product ID: ros-monosys
              Speedmaster Mono Hardware System
              Douggie
              • SJFE
                • 4867
                #37
                I have to agree with Douggie. That motor is way to small and the kv rating is off the chart for your hull & voltage. Sorry.
                • bababoboRc
                  • Mar 2008
                  • 26
                  #38
                  Thanks for the feedback guys
                  what motor would you recommend forthis hull, i want to use it as a sport boat but still want to get decent speed out of it
                  Douggie
                  i'm not surw what you mean by your setup is on borderline?
                  excuse my ignorance i'm new at this elecric stuff
                  Cheers
                  Adrian
                  is this the stinger ? .187 (3/16-inch Cable) for .21 - .40 motors
                  rudder ?.40 Rudder Assemblies
                  • Flying Scotsman
                    • 5195
                    #39
                    Hi Adrian, when I say borderline the esc is rated for 100 amps and the 11XL motor is rated at 1500 rpm per Kv. I am using 5S LI-PO therefore nominal RPM= 27,000. The hull is 32.5" L and total weight is 5.3lbs. I am using a small diameter prop Y537/3 to limit the amperage draw...I hope!!!
                    This hull size and weight is more suited to a large can high torque motor...KB45 XL, Neu power or transmission with Feaigo power. This what I had sitting arround and I hope it does not go POOF.
                    I hope this helps.
                    Douggie
                    • bababoboRc
                      • Mar 2008
                      • 26
                      #40
                      Hi There
                      Thanks Douggie for your feedback i got my hull today looks good in white
                      i also took your advice and brought two motors
                      this one http://www.hobbycity.com/hobbycity/s...idProduct=4937
                      and this
                      will give these a run ,cheap motors really $ 53 each
                      Regards Adrian
                      • Flying Scotsman
                        • 5195
                        #41
                        [QUOTE=bababoboRc;31890]Hi There
                        and this
                        Adrian, motors can be cheap, quality esc and motors NO!!! If you look at the power to bucs equation
                        • bababoboRc
                          • Mar 2008
                          • 26
                          #42
                          Hi there Douggie
                          Sorry to be a pain but i cannot find the rudder you are using on the speedmaster site is it a 21 mono rudder or the 40 rudder cheers
                          Adrian
                          • Flying Scotsman
                            • 5195
                            #43
                            Originally posted by bababoboRc View Post
                            Hi there Douggie
                            Adrian
                            No pain....21 but you may wish to lower the rudder as far as possible.
                            When you get the hang of it, there are many guys that can help you, with more experience than myself.
                            Enjoy your build.
                            Douggie
                            • bababoboRc
                              • Mar 2008
                              • 26
                              #44
                              Thanks for the help Douggie
                              i will put some pics as soon as i make a start on this build
                              Regards
                              Adrian
                              • bababoboRc
                                • Mar 2008
                                • 26
                                #45
                                Hi Douggie have you run your boat yet ??
