This is my first rigger so I thought I would document the build and also ask questions along the way. Here are the pics as the boat came from Eric. I was lucky enough to get 1 of the 2 made on his second batch.
You can see I am test fitting a 2200kv Castle motor I have. I think I have a water jacket that will work for this motor, but will have to check.
I actually already have a question. The stuffing tube is already glassed in as you can see. I need to run a tube inside a tube basically. The tube that fits the strut will not fit through glassed in tube, so I guess I would need to solder a slightly smaller tube to the one that goes in the strut to make it all work. I am betting there is some other better way to do this?
