Fountain Rio Refit.
  • Ctonez
    • Jul 2007
    • 410
    Wow, you are productive...at least compared to me.
    Out of 5 boats to get ready by mid-March, I am finished with only 1...my Spec SV from last year.
    I am really into this build. It's really unique in so many ways...the hull, the hardware, the configuration. You gotta have video of the maiden voyage!
    • SJFE
      • 4867
      Done
      This ones done. I did the finish work this morning. I wired up the lvc and s-bec to commen 3mm plugs and mounted them as a single removable unit. I went with the jeti esc due to the space. The rchydros will go in the runner. I remembered my flotation this time. It looks like I may have to trim the strut bracket about a half inch if it interfears with the prop. The rudders still need to be perfectly alined. I will be in the water and recording by mid morning tomorrow. I don't have enough connectors to convert my dpr but I will have the gps. I'll get to the dpr next week. Up next is the bud hydro. I ordered new factory HW from horizon. It will be here tomorrow. All I need now are my decals from Tim and this one will be completely finished.YeeHaa
      • kck741
        • Aug 2007
        • 282
        wow you cleaned it up nicely,one ? where can I order some of the CF Cloth you are useing I really like it.
        S.S.R.C-Southern Style Radio Control
        • SJFE
          • 4867
          That was factory. PM me your email and I can set you up with some cloth.
          • SJFE
            • 4867
            #35
            & the thread goes on. Ok so the Wolf and I have worked out some mods to the hardware. It's not a matter of the HW being wrong. It's that I asked for the wrong thing. So now the rudder standoffs are being removed. In their place will be shortend composite plates with ajustment options. We have elected to remove quite a bit of weight from the base plate also. I think this will get the stern out of the water and unload the prop quite a bit. I should be back to work on her in 2 weeks. By then the plett will be here.
            • Flying Scotsman
              Fast Electric Adict!
              • Jun 2007
              • 5195
              #36
              SJFE, a very clean install of all components on a used hull
              Douggie
              • SJFE
                • 4867
                #37
                It's really a a requirement on my part for everthing I setup. I know if it don't or I can't make it look clean I won't bother keeping it.
                Thanks Douggie
                • SJFE
                  • 4867
                  #38
                  Sometimes you just have to say "F" it. When I am done with this stern mod it won't be a matter of what HW can I make work. It will be picking what I want to install. I am shoping for it now. I want this mod done by the end of the week. Wish me luck.
                  • G Doggett
                    • 477
                    #39
                    Oh dear !
                    Don't look now but there's a big hole in the back of your boat !!!!
                    I have ordered a pair of Aquajet nylon rudders and brackets for my Rio, only $9 each from OSE. Yeah I know I'm cheap.
                    I think they will look quite scale and being black they look a bit like a pair of stern drives, if you use your imagination.
                    Keep up the good work.
                    Graham
                    • Avanti
                      • Nov 2007
                      • 1298
                      #40
                      Tom what the bejesus are you up to? that is a mamoth hole
                      The Manx has been sitting dormant, but I think I finally have my motivation back. I hope to see it float soon.
                      • SJFE
                        • 4867
                        #41
                        Im going to fil it with gun powder and ram a fuse in it...lol
                        • Avanti
                          • Nov 2007
                          • 1298
                          #42
                          I'm guessing your building a stand off bracket with a flat back am I close
                          • SJFE
                            • 4867
                            #43
                            Very but not off "in". The hull is so narrow and long stand off's are not a good idea. I only want the strut off an inch max.
                            • Steakhouse
                              • Dec 2007
                              • 128
                              #44
                              Tie that boat to a tree and shoot it
                              Im just kidding, i do the same thing. I spend 10 hours on a 10 minute build and it ends up in the garbage anyway!
                              • SJFE
                                • 4867
                                #45
                                Every just want to cut out the BS? Try is some time it relieves alot of stress. The stern is @ a 90 now. It's set up in DC and cureing for the night. After some sanding and a couple brackets to sure it up the HW install will be a total snap .
