Almost done redoing the hatch, a few questions before I order packs. What is the CgG on riggers? I am thinking of putting a 2S pack up front of the motor, and a 3S pack behind, for 5S total. will this put the CG too fat back?
36" rigger
Cg on riggers is like taste in women. There are a few basics and the rest is taste.
A common place to start is with the Cg 10% aft of the rear of the sponson rear.
This measurement is taken from the rear of the sponson to the prop hub and then 10% of that.
I run up to 25% for different hulls and different types of runs but 10 is a good place to start.See it....find the photos.....sketch it it....build it........with wood
Should I run the reccomended 7/32 tubing with no teflon for the flex? I've seen some people run 1/4 with no teflon, what is reccomended?
Edit, I know i've been asking a lot of questions, but I'm considering props, i'm gonna go with a TFL 47mm, and I can't decide between an x447 and a 2047, which one would be better for my setup? (1970kv on 5S) note: the motor is OR so it should be able to spin a slightly larger prop.Last edited by Boaterguy; 06-15-2011, 09:26 PM.
I cant help you much there as I run my home brew wire drivesOriginally posted by Boaterguy View PostShould I run the reccomended 7/32 tubing with no teflon for the flex? I've seen some people run 1/4 with no teflon, what is reccomended?
Keep in mind there is a massive difference between a 447 (1.4 pitch) and a 2047 (2.0 pitch)Originally posted by Boaterguy View Postbut I'm considering props, i'm gonna go with a TFL 47mm, and I can't decide between an x447 and a 2047, .
I find a big jump going from 1.4 to 1.6 in the same dia prop. e.g a 437 to a 637See it....find the photos.....sketch it it....build it........with wood
I'd start small with the props, 1970 kv on 5s is a lot of RPM (41k unloaded), too big of a prop will make the first run really short. I would drop down to something like an x442 or x440 for the first run.Light travels faster than sound, so people may appear to be bright until you hear them speak.
Loading up a motor to keep the revs down will cause it to heat up and draw a lot more current.
Until you nail down a good prop size, just get some cf props, no need to S&B. Plus they're much cheaper to have a pile on hand.Light travels faster than sound, so people may appear to be bright until you hear them speak.
I think I figured out my props
TFL 47mm for high speed single or double passes since the temps will get up there
X442 for less speed and to let others try it, since they can put some abuse on the motors without worrying about temps too quickly
K40 will be a small prop for cruising, no full throttle (i'll set a DR on my TX) since carbon's can deblade at 35k, don't want that happening, yeeouch!
new hatch finished, I did a different one but I didn't like it so I got rid of it and made an open hatch
I might add something later, but I like the motor sticking out the top
