36" rigger
  • Boaterguy
    • 1779
    Aright, well thanks for comforting then :) I was worried you would know my address too
    • Meniscus
      Refuse the box exists!
      • 3312
      With that setup, you'd be seeing 53mph on M445, 55-56mph on x447.
      • Simon.O.
        • 1611
        Originally posted by Boaterguy View Post
        so, If I go with the 1600 on 6S, I get 37k unloaded, That seems fine.
        Looks like a bit happened while I was typing my last reply.
        1600 on 6S is not too mad. I have one that I am shaking down now. It is a new hull and it will take a bit of sorting but is a reasonable setup with a 438 and then I'll try the bigger props.
        Keep in mind that this 1600Kv motor is an OR (outrunner)
        • Boaterguy
          • 1779
          http://www.offshoreelectrics.com/pro...-540XL&cat=116
          this is the one I had in mind, on the 1600 or 1800, 1800 would be on 4 or 5S
          • wparsons
            • 461
            Depending on weight, I think you want something bigger for a motor, and on 6s to keep amp draw down:
            http://www.offshoreelectrics.com/pro...o-4082&cat=148
            That in the 1500kv wind is a powerful motor.
            Light travels faster than sound, so people may appear to be bright until you hear them speak.
            • Boaterguy
              • 1779
              I checked all the motors, on my budget (third post), I just can't get such a big, expensive motor, I wish I could get something that nice.
              • wparsons
                • 461
                Fair enough, I just don't see you getting 60-70mph from a 540XL in a 36" boat though. The other estimates of mid 50's is more realistic.
                Other than having already started on the hull, why so big if you're on a tight budget? On a smaller hull you could get the same (or more) speed on more affordable equipment.
                • Meniscus
                  • 3312
                  Don't get discouraged. I would recommend sticking with 4s2p for the time being. That power source will push you to the speeds you want and it won't cost as much for an oversized motor to make it happen. It is typical to run a 4s rigger at speeds up and over 75mph while remaining cool.
                  • Meniscus
                    • 3312
                    Parsons is right. For a 4s rigger made out of wood, you may want to consider a slightly shorter hull. It can be done, but it is recommended to start with something proven first.
                    • Meniscus
                      • 3312
                      Put it this way, there are some in Europe that run riggers as large as 33" on 3s1p and less than 45 Amps. These riggers are setup for oval racing and typically run 75mph+ in the straights. That being said, you have to understand that these are very light builds and are typically made of light lay up fiberglass or carbon.
                      • wparsons
                        • 461
                        Damn, those must be really light and slick hulls to hit 75+ mph on ~550 watts! For a 4s rigger, how many of the ones running in the 70's are going it on a Feigao 540XL? Those motors just don't have the oomph that a bigger neu/leopard/lehner/etc does.
                        • Meniscus
                          • 3312
                          They actually run 3600kv outrunners. Let's just say they plane out well and are very neutral aerodynamics.
                          • wparsons
                            • 461
                            ^^ Which ones run 3600kv outrunners? The 3s ones in Europe, or the 4s ones in North America?
                            • Boaterguy
                              • 1779
                              I just wanted one this big because it was initially intended to be gas, not electric, but I have no experience with gas so I wanted to keep this where I was experienced. I think I'll go with a 4S on either 1800 or 2000, on the 540XL. I would love to run this on a neu 1515, a nice leopard, or a lehner. I just don't have the money. Being 14, I do not have a job that pays minimum (15 is the minimum age in Canada). I teach snowboarding in the winter, and make about 60$ a year. I delivered papers, that brought in a hefty 400$, at 10$ a week. I am gonna go with the turnigy 180, so 5S might be a bit better of a plan, to keep the amps down. hardware can be picked out at low prices, a rudder from HK (already found one, and I have done my research, it is a good one.
                              I'll get a strut, motor mount, shaft, and maybe batt from OSE. I guess 50-60 mph is an easier goal.
                              • Meniscus
                                • 3312
                                3s in Europe
