Whiplash Sport 20 Build
  • oscarel
    • Dec 2009
    • 2135
    #61
    Yes, I've been in touch with Mike. I'll have to see how that one turns out, that may make it 3 things to tape down. I've made it so everything is waterproof, I flipped it and it was upside down for about 5 mins. Brought it in, drained water and back in it went. I've been using the Hitec HS-5646WP servos in just about everything I have and they're working great. That along with the T180 which I sealed around the seams and a FlySky with a squirt of corrosionX.
    • oscarel
      • Dec 2009
      • 2135
      #62
      I actually had a vac-u-pickle cowl that I was fiberglassing over, had it all primed and drying. Left it on the garage floor on cardboard to dry. Bad move, wife drove over it... Won't do that again.
        • 4297
        #63
        lol lol, Sorry.
          • 4297
          #64
          Good to hear, So I guess no fishing for it yet.
          I had to do that the other day for my mini bolt,
          But it stays dry inside with the seal I made, No tape.
          Originally posted by detox View Post
          Today I ran the boat using the M447. Boat jumped up on plane instantly, but water was too wind choppy rough to let her rip. Boat looked pretty good from what I could see. Here is my first Hydra Ice data log. The second Green group 350 amp spike is where I nailed the throttle from stand still. Next time I will be a little easier on throttle by tossing the hull as in first Green amp group. (amps peaked about 225 during hard throttle while running).
          The Yellow 3M electrical tape does not hold as well as the White. My UL-1 nose cone fell off during run because of it. Had to retrieve it using tennis ball and fishing pole. The tennis ball and fishing pole method works Very well. Better than getting wet.
          • detox
            • 2310
            #65
            Since I purchased another Whiplash 20 kit back when they were on sale. I may build a new larger version that will qualify for larger Q Sport Hydro class (34"-40"). Hull will be lengthened in center section and transom. Sponsons will have to be larger also. I also remembered the 60 percent afterplane rule.
            • detox
              • 2310
              #66
              These people have verygood prices on plywood. I ordered a few 12"x48" sheets of various thickneses. Free shipping if you order over $150.00 worth. It will be shipped in cardboad box resembling a firearm box. Wood quality is verygood
              National Balsa is a great choice for all your Plywood needs. All our Plywood is premium model grade quality wood. We offer Baltic Birch and Italian Poplar Lite Plywood. Our plywood comes in the thicknesses of 1/64, 1/32, 1/16, 3/32, 1/8, 3/16, 1/4, 3/8 and 1/2 and the convenient lengths of 12", 24" and 48".
              • steveo
                • 1454
                #67
                Talking about wasteful spending. From left to right... Neu 1527 .5y 2500kv, 1518 1.5d 2300kv, 1515 1y 2200kv. Hyda ICE LV esc and Two Grimracer 4s 4200mah packs..
                i would say tasteful spending, but thats just me lol
                • detox
                  • 2310
                  #68
                  Just started my 34" Q Sport Hydro build. Using bandsaw I cut out longer framing (extended 4" @ stern). Two 2 1/2" x 48" strips of 1/8" plywood were laminated together using 3M contact spray adhesive then Four pieces were cut out.
                  • detox
                    • 2310
                    #69
                    OH YEA! Here is first video. Boat turns verygood using the Virginia Craftsman Sport 40 fin. Max prop rpm 36000 (logging set at 4 pole 2500kv motor), average amps pulled 230, Motor temp 123, Lipo temp 93, ESC temp 150. Boat is capable of more speed...need more prop
                    I am using two 4200mah packs totaling 8400mah. Total mah used during that run was 3276mah
                    I had to add the White nose cone locator pad in picture so my nose cone would stay on and not fall off. This locator pad has the same size and shape as one used on UL-1. This keeps the nose cone from sliding around and breaking free of tape.
                    • oscarel
                      • Dec 2009
                      • 2135
                      #70
                      Looks good. Your average was 230 amps?
                        • 4297
                        #71
                        Very very nice Keith,
                        Looks like she a good runner.
                        • detox
                          • 2310
                          #72
                          Thanks Guys. You can tell by the way it sounds or screams motor is turning alot of rpm. The amps being pulled (260-200) appear to be running on ragged edge of ESC specs. I hope she lives during the hot summer. I also plan on trying a lower 2030kv motor and larger prop. Some say slowing the prop down makes prop more efficient.
                          • jcald2000
                            • 768
                            #73
                            At 230 amps ave. in 1 min., I assume that means 3276 used from EACH 4200?
                            Those .05 turns shore do eat.
                            If thats the case it won't make a heat race.
                            • detox
                              • 2310
                              #74
                              No...thats 1638mah used per 4200mah pack. OR like I originally said "I am using two 4200mah packs totaling 8400mah. Total mah used during that run was 3276mah"
                              • detox
                                • 2310
                                #75
                                My next Q Hydro Whiplash is 1.5" wider and 4" longer than stock. Totalling 34" long
