if you had two identical boats both with 2000kv motors both propped to go 40 mph one on 4s and other on 5s would they both draw similar amps and have close runtime
4s vs. 5s same speed
No. It takes a certain amount of power (watts) to go a given speed. Volts x Amps = Watts. With a higher voltage, you need a lowe curren tto achieve the same power.Originally posted by steveo View Postif you had two identical boats both with 2000kv motors both propped to go 40 mph one on 4s and other on 5s would they both draw similar amps and have close runtime
Runtime is relative to current draw, so obviously this would change as well.
