4s vs. 5s same speed
  • steveo
    • 1595
    if you had two identical boats both with 2000kv motors both propped to go 40 mph one on 4s and other on 5s would they both draw similar amps and have close runtime
  • 6sHyper
    <<<Surfs up!
    • 640
    I would imagine the one on 4s would have shorter run times and draw more amps as it would have to have a larger prop.
    • steveo
      • 1595
      i put this thread in the wrong place could someone move it
      • keithbradley
        • 3671
        No. It takes a certain amount of power (watts) to go a given speed. Volts x Amps = Watts. With a higher voltage, you need a lowe curren tto achieve the same power.
        Runtime is relative to current draw, so obviously this would change as well.
        www.keithbradleyboats.com
