Project Mean Machine - Castle 1717 on 6s
  • FighterCat57
    "The" Fighter Cat
    • Apr 2010
    • 3784
    OK, so I picked up a hull/hardware Mean Machine and the used 1717 I had on the bench said, mount me, I need a new home. So... I did. No room for a cooling can, but this is a sport setup, so in it goes canless. I have some ideas to zip tie fans to the sides if need be, but will cross that road if I get to it.
    Don't have any cables to fit this size stuffing tube, but it's got a 3/16" strut, so I cut an 078 wire and soldered up a drive for it. There's a bit of a bend, but it's pretty smooth. I've run these wires with quite a bit more bend. It may break, but it'll be from fatigue over time, probably not immediate. I'll have to figure out a way not to lose the prop when that happens...
    I'll probably end up with a seaking ESC, but figured I'd test a Suppo 200 ESC kit on 6s. Soldered it up with a capacitor and used thermal grease to ensure the FET's touch the cooling block. Most importantly I soldered up a resistor so there'll be no spark while hooking up the batts.
    As for the batts, I've got two options. Some good sized 3s packs in series or two 25c 6s long lipos in parallel. Will start with the 3s in series to keep things light.
    Not sure what starting prop. Might be an m445 if my thoughts are correct, that should be a good sport setup with plenty of run time and a fun amount of speed.
    There's plenty of velcro in the sponsons for moving the COG as necessary and the strut has plenty of adjustment. This hull was setup nicely when it was built. Thanks for that. =)
    Here's some photos. Might get it wet this week.. but most likely next week.
    We'll see how I feel in the morning.
  • millzee
    Ozzie Bloke
    • Nov 2010
    • 1097
    would it be worth trying a silicone jacket just up on the back half of the motor, I have found that these motors seem to get the hottest near the back end when using them in my truck.
    "Gimmy Toyz for FUN"
    • rearwheelin
      • 2101
      Dont even worry about the wieght. That hull runs light ! This is a picture of my first cat build.....Twin MM on 6s, 9t 540xls, 447s........Too fast for this boat.
      --Albert Einstein
      • FighterCat57
        "The" Fighter Cat
        • Apr 2010
        • 3784
        Good to know! It looks like it'll pickup quite a bit of air!
        It's ready for the water, so just waiting for the weather.
        • Alexgar
          • Aug 2009
          • 3701
          I used a m545 on my apparition on a cc1515 5 s and was really happy though I had to watch my run time cause a water jacket won't fit hope that helps
          • steveo
            • 1595
            make sure that motor mount is secure, dosent look like much epoxy there
            • satan_in_secret
              • Apr 2010
              • 32
              my cc 1717
              fins were cleaned
                • 9481
                Oh man, and to think I just put in a MG motor and esc in mine two days ago and yours in going to
                • FighterCat57
                  "The" Fighter Cat
                  • Apr 2010
                  • 3784
                  Originally posted by satan_in_secret View Post
                  my cc 1717
                  fins were cleaned
                  Out of curiosity, what was the purpose of losing the fins?
                  It's neat looking like that.
                  PS- "satan" is on the disallowed list at my site if you were wondering. Nothing personal... unless you are satan...
                  First run went great, but I'll have to get an antenna mount. It dropped signal in the middle of a run. I thought something broke. Nope. She drifted in with a blinking rx light.
                  It's fast, smooth and needs a bigger prop!
                  Plenty of room for 6s2p and lots of run time. Going for max fun/speed/runtime sport combo. I think this is a ringer.
                  I'll try to get some video on the next run out. Maybe saturday.
                  • Alexgar
                    • Aug 2009
                    • 3701
                    What next x646 or x447?
                      • 9481
                      what prop are you thinking now?
                      • FighterCat57
                        "The" Fighter Cat
                        • Apr 2010
                        • 3784
                        M445 and then m447. I have a feeling that I could run the 450...
                        • LarrysDrifter
                          Big Booty Daddy
                          • May 2010
                          • 3416
                          That motor wing swing a 50mm without trying. It likes bigger props.
                            • 9481
                            wow, a 50mm on this little hull
                            • FighterCat57
                              "The" Fighter Cat
                              • Apr 2010
                              • 3784
                              Yeah, that's what I'm thinking. It seemed to hit peak RPM almost instantly. Talk about power.
                              Again the goal here is to over spec the hardware and run it mildly for sport use. The end result being a reliable, fast and fun boat.
