Project Mean Machine - Castle 1717 on 6s
    • 9481
    now you have me thinking of using a CC1717 in my MM
    maybe an air motor without a cooler
    do you have a support under the end of that big motor?
    • FighterCat57
      "The" Fighter Cat
      • Apr 2010
      • 3784
      I just bolted it in. No cooling. No heat either. It's a sport setup, so doesn't get hot... Yet. =)
      I'm working on a 1717 air motor mount for the Genesis. Since there are so many out there. No cooling can, just change the tail ring and coupler in the stock setup.
        • 9481
        do you have some bigger mounts for the CC1717 motors.. car and air versions?
        • FighterCat57
          "The" Fighter Cat
          • Apr 2010
          • 3784
          Hopefully. Time will tell.
            • 9481
            Ok, I'm looking for a mount for my PT SS45 for a CC1717 motor
            • Make-a-Wake
              FE Rules!
              • 6057
              M445 and then m447. I have a feeling that I could run the 450...
              An x645 may be a good option as well................
                Originally posted by satan_in_secret View Post
                my cc 1717
                fins were cleaned
                Nice but, I can make coolers for 1717's on my lathe as easy as skinning a motor.
                Besides, I think the motor stays cooler with water cooled fins.
                Nust have been a pain in the arse to keep the wires held back.
                  That motor I have to say is waaaay over kil but, what the heck!
                  I used a T600 1400Kv outrunner in the heavier Phantom cat with an x450 D/T prop on 5S OLD cells. About 55 mph...
                  I'm trying a Suppo 1970Kv motor in it now on 4S, We'll see if I can turn a nice prop still.
                  • FighterCat57
                    "The" Fighter Cat
                    • Apr 2010
                    • 3784
                    That's kinda the point. Running a motor with plenty of head room, hoping for long and reliable runs.
                    I'm also going to try one of the 3740 outrunners to see how it does.
                    • FighterCat57
                      "The" Fighter Cat
                      • Apr 2010
                      • 3784
                      Test runs went well... until the prop shaft seized in the strut bushing.
                      Not sure what happened there, maybe the cable was too tight, I dunno... but it's seized to the strut bushing.
                      Handles nice, it's a fun little boat. Looks like I'll get a wire drive setup now. The tapered rudder seems to have helped the cornering. It was a bit choppy so I didn't push it.
                      • jingalls007
                        • 1172
                        Try a 452/3 if you really want some fun! That's my new favorite prop for this setup, Hydra 240, NEU 1521 1.5D, 4s2p, .21 sprintcat- same hull as the mean machine. no heat anywhere with this setup.
                          • 9481
                          Jarrett, I would love to see that run!
                          where abouts do you live?
                          • FighterCat57
                            "The" Fighter Cat
                            • Apr 2010
                            • 3784
                            Sounds like a plan! Think I have a 450/3 so can inch closer to it.
                            I'm also thinking I'm going to start using the 6s long lipos for 6s2p.
                            • forescott
                              Hopelessly Addicted to RC
                              • 3009
                              Lookin good Ben!
                              • FighterCat57
                                "The" Fighter Cat
                                • Apr 2010
                                • 3784
                                Originally posted by forescott View Post
                                Lookin good Ben!
                                Hey, your avatar kinda looks like my new boat!
                                Is this a special paint or a factory paint? I think I've seen it elsewhere, but might have been this boat elsewhere?
