Great lookin' build Millzee, Almost want to get one myself now.
Have you had a chance to run it yet?
I had the trim tabs up way too high for this first run due to my only experience being the df35 that I had running too wet and all this has taught me is that these boats seem to be complete opposites in handling. I will lower the trim tabs to level with the bottom of the hull and I will stick on the x445 or maybe the m545 to see what happens. I think it's time for me to get the eagle tree system up and running to save any smelly hull syndrome. The strut might need to be lowered a bit too to keep her down a bit. The batteries up front put the rtr cog somewhere between 33-35%, would my guess of a combination of the high cog, the strut level at zero and the prop a little small be what's causing the cavitation? Also, can someone let me know if there's a big difference in amp draw between the octura 445 and 545, I understand different hulls will pull more and so forth but I'm hoping someone may have ran both of these two prop's and have logged some data.
I had the trim tabs up way too high for this first run due to my only experience being the df35 that I had running too wet and all this has taught me is that these boats seem to be complete opposites in handling. I will lower the trim tabs to level with the bottom of the hull and I will stick on the x445 or maybe the m545 to see what happens. I think it's time for me to get the eagle tree system up and running to save any smelly hull syndrome. The strut might need to be lowered a bit too to keep her down a bit. The batteries up front put the rtr cog somewhere between 33-35%, would my guess of a comination of the cog high, the strut level at zero and the prop a little small be what's causing the cavitation? Also, can someone let me know if there's a big difference in amp draw between the octura 445 and 545, I understand different hulls will pull more and so forth but I'm hoping someone may have ran both of these two prop's and have logged some data.
The impact broke the epoxy off where I'd fitted the front hatch hold down and the tape lifted allowing about 1/4 cup of water inside the hull. I'm sure everything will be fine, not a lot of water got on the electronics and my cameraman drove it back in to shore. Once I opened it up I also noticed the esc mount I'd epoxied had also come loose on one side so I guess I'll have sand the area better and do a little more work b4 I can get her wet again.
