Wow nice paint scheme ! Personally if it was me I would leave it for a day or 2 to harden
Aeromarine Titan 29" My 2nd build
Prince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.
I just ordered a few more goodies to make up a reasonable order with the cooling jacket. I got the b&s m545 to try otherwise I have a a x640, x642, x440/442/445. I also got a m447 but I think I'll be useing that on the 35" pirate.
Originally posted by millzee View PostI'm making progress with my painting attempt, I thought I'd share a few pic's of the color's be I give it a lite rub with wet 1200 paper and add the decals and clear coat. Should I wait a few days for the paint to fully harden b4 taking the next step or should I just get it done now, the paint's been dry for about 3 1/2hours??
Nice paintjob!
Reminds me alot of my Vintage Latrax Cigarette boat................did this scheme about 2 years ago.................Attached FilesNEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
OMG, is that cherry red with metallic charcoal I'm seeing there? Gee it's hard to be original when ya come into a hobby so late. Well done, it looks great!
Hi, Looking good, I let mine dry 1 day and I place graphics on before clear coating.Originally posted by millzee View PostI'm making progress with my painting attempt, I thought I'd share a few pic's of the color's be I give it a lite rub with wet 1200 paper and add the decals and clear coat. Should I wait a few days for the paint to fully harden b4 taking the next step or should I just get it done now, the paint's been dry for about 3 1/2hours??
Attached another Titan 29 paint scheme. I own 2 and I am very happy with mine.
Keep up your good work. Regards
Norman2Attached Files34" Ekos Cat UL-1 Powered
thanks for the nice feedback guy's. I got the lid sprayed and some electronics done today so I'll wait until tomorrow before I get the hull ready for the clear coat.
You will probably want to stay away from your bigger props. I basically had the same setup with a CC Hydra 240 and my caps ran pretty warm, too warm for the summer. My final prop was the 440 3 blade..Mine ran 53 mph and looked as if it could handle more speed. Your hardware setup will determine how fast you will be able to take that boat......Like Fluid says , it does run light....Here is a couple pics of mine. If I built this boat again I would use my own motor mount and put closer to the transom, run a offset rudder, use ''Super epoxie" and build my own turn fins from 2mm CF.....Basically how I am doing the Rico...ha ha...My old Titan was able to handle 50 + with never a blow over in semi calm weather ! If you want a link to the vid I can do.."Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
--Albert Einstein
More video the better I say, that'll be very handy for me to veiw, Thanks.Originally posted by rearwheelin View PostYou will probably want to stay away from your bigger props. I basically had the same setup with a CC Hydra 240 and my caps ran pretty warm, too warm for the summer. My final prop was the 440 3 blade..Mine ran 53 mph and looked as if it could handle more speed. Your hardware setup will determine how fast you will be able to take that boat......Like Fluid says , it does run light....Here is a couple pics of mine. If I built this boat again I would use my own motor mount and put closer to the transom, run a offset rudder, use ''Super epoxie" and build my own turn fins from 2mm CF.....Basically how I am doing the Rico...ha ha...My old Titan was able to handle 50 + with never a blow over in semi calm weather ! If you want a link to the vid I can do..
Thanks for the advise, I have to wait for batteries and a few other things and then I'll start trying a few, I ordered the m545 which from with all the reading I found a few folks were happy with it.Originally posted by Alexgar View PostI tried the x442 and it worked ok but everything was cool went 445 545 646 and was really happy with the latter two warmed up my wire alittle but with a 200 amp discharge rate and 2 water pickups it came in alright
Don't lauph at my nareration, I had just sold the boat to a friend and got excited for him and tried to keep him from crashing it...ha ha !....He was running my batts in it !http://www.youtube.com/user/rrandydduke#p/u/LXUVom1naA......this is the link to my channel...find the " file 0068 mov.'' on the play list. 53 mph Titan !"Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
--Albert Einstein
looks good, ride high and seems stable, I hope I get mine to do the same, thanks for the link
Nice..Originally posted by rearwheelin View PostYou will probably want to stay away from your bigger props. I basically had the same setup with a CC Hydra 240 and my caps ran pretty warm, too warm for the summer. My final prop was the 440 3 blade..Mine ran 53 mph and looked as if it could handle more speed. Your hardware setup will determine how fast you will be able to take that boat......Like Fluid says , it does run light....Here is a couple pics of mine. If I built this boat again I would use my own motor mount and put closer to the transom, run a offset rudder, use ''Super epoxie" and build my own turn fins from 2mm CF.....Basically how I am doing the Rico...ha ha...My old Titan was able to handle 50 + with never a blow over in semi calm weather ! If you want a link to the vid I can do..
I have a Medusa 3670 2300kv in mine and I will look into running a X440/3
mine just wants to lift above 45mph+
Hi Millzee, Your boat is looking good. Thought I would remind you to place someOriginally posted by millzee View PostI just ordered a few more goodies to make up a reasonable order with the cooling jacket. I got the b&s m545 to try otherwise I have a a x640, x642, x440/442/445. I also got a m447 but I think I'll be useing that on the 35" pirate.
flotation foam in the forward section of the hull. Just so you will not loose your
boat should you have a spill. Regards
Norman234" Ekos Cat UL-1 Powered
