32" hotr 90+mph
This topic is closed.
  • Howard Lee
    • Nov 2010
    • 202
    My genesis
    • keithbradley
      • 3671
      Originally posted by Howard Lee View Post
      Tomorrow i will show you same pics of how i balance the boat. With this and a gps you will find your top speed.
      You said your balance point is at 12"...Do you mean from the transom or from the back of the sponson?
      www.keithbradleyboats.com
      • rearwheelin
        • 2101
        Get a pool noodle and cut it in half long ways the lenght of you lipo's and wedge it on top of them between the upper deck to keep them from any movement, just the velcrow could let them bounce a little and give the boat a slight upper jolt.............like your style bro ! Your trying to provoke a speed war....HaHaHa !!!
        --Albert Einstein
        • Howard Lee
          • Nov 2010
          • 202
          • rearwheelin
            • 2101
            #35
            I am done now...........Its time to see what happens
            --Albert Einstein
            • Howard Lee
              • Nov 2010
              • 202
              #36
              I start at the very rear where the rudder mounts.
              • LarrysDrifter
                Big Booty Daddy
                • May 2010
                • 3416
                #37
                You should measure from the rear of the sponsons.Same place where a stinger would mount if it were a twin drive.
                • JPriami
                  N4FOX
                  • 1711
                  #38
                  • TotalPackage
                    • 622
                    #39
                    Nice azz build howard I wish you well bro. The thread says 90 mph good luck dawg
                    • Howard Lee
                      • Nov 2010
                      • 202
                      #40
                      I was just thinking if the hull was not square the very rear of the boat would be the best place to start from.
                      • 6sHyper
                        <<<Surfs up!
                        • Jan 2011
                        • 640
                        #41
                        what kind of rudder is on there??
                        • Howard Lee
                          • Nov 2010
                          • 202
                          #42
                          Is from Fine Design.
                            #43
                            84 mph with a Leopard 4082 doesnt compute in my little brain...
                            In theory all he needs is 6S and a v942/3 prop to get there. It would be a SAW-only setup and would stress the ESC (what ESC is he using?), but it is possible in theory. I doubt the boat could set a record but it might hit 90 on the GPS....but not with the CG so far back.....
                            • JPriami
                              N4FOX
                              • 1711
                              #44
                              You mean you bought something from Chris and actually got it?
                              • Howard Lee
                                • Nov 2010
                                • 202
                                #45
                                I will show you how i balance my boats. First you need to run the boat and find a good spot to start from. Then make a mark on the boat where you balanced it at. Run the boat and check your speed. Now move the batteries only a 1/4 of a inch at a time. This might take some time to find your best balance. Also your prop angle needs to match your balance. Think of your prop as if its drawing a straight line. If your prop angle is to high, you will have a nice rooster but this will not be the fastest setup. This might help some of the less experienced.
