32" hotr 90+mph
This topic is closed.
  • Jacked1
    • Jun 2010
    • 787
    #406
    I've ran one over 100mph on 9s.
    Not in a boat though
    Sweet! I figured it is pretty close in kv and have handle more amps. Along with being dirt cheap right now.
    • carlcisneros
      • Jan 2010
      • 1237
      #407
      Thanks Howard.
      will let you know how it goes after next weekend.
      BTW, the pic in my avatar is when it had the CMB 90 in it.
      martno1fan;
      those are the T600 1400KV motors in my twin mono.
      will be on 6S2P
      (2 6S packs hooked up in parallel powering both ESC's.)
      Carl
      • FighterCat57
        "The" Fighter Cat
        • Apr 2010
        • 3784
        #408
        Originally posted by Jacked1 View Post
        Howard, Have you considered using a castle 1717 on your Genesis to see if you can push it over 100 as well? I have not seen a higher voltage setup with one yet.
        I'm working on a tail ring to mount the 1717 air motor in the Genesis mount stock. Just a bolt in. If anyone does machining, mock up a 46.5mm tail ring and see how the 1717 does! I have three ready to test!
        • Jacked1
          • Jun 2010
          • 787
          #409
          Once again! You are one step ahead!!
            • 9481
            #410
            Dang, that's like a Big Block in a VW
            • TotalPackage
              • 622
              #411
              I need to buy one please.
              Whats up Howard what up for today ? You runnin?
              Hey guys why not try your t600 oon 8 or 9 s ? it rated to handle 8 anyway
              • Howard Lee
                • Nov 2010
                • 202
                #412
                I'm working on the 32 it had some problems but its looking good. I wish i didn't try working on the prop i hit a 100 with.
                • Howard Lee
                  • Nov 2010
                  • 202
                  #413
                  My 32 on the last run started to have a pull to the right on full throttle. I found the stuffing tube had a slight bend. I will do some more testing this week and see if i can make a better vid.
                  • Howard Lee
                    • Nov 2010
                    • 202
                    #414
                    If you have a strut with smooth sides you will want to take a dremel and cut some small grooves into it. This will help it from moving and change your prop angle.
                    • FighterCat57
                      "The" Fighter Cat
                      • Apr 2010
                      • 3784
                      #415
                      Some say drilling for a second bolt is a good idea as well. The extra grip certainly does help.
                      • Howard Lee
                        • Nov 2010
                        • 202
                        #416
                        I thought that would work because i have 2 bolts holding my strut together. Every time i would run and then check my prop angle after it was different. Now with the grooves is never changes. I learned the hard way with my genesis when i 1st started the strut moved and broke my stuffing tube and twisted the drive shaft that broke a hole in the hull from it. It was about that time when i stop with 3/16 and went with .187 drive.
                        • Howard Lee
                          • Nov 2010
                          • 202
                          #417
                          Ben do you know what the hp is on a 1515? 60 would be nice.
                          • keithbradley
                            • 3671
                            #418
                            If you have your strut where you want it, adn intend on using a second bolt to hold the strut from moving, the second hole should be the same size as the bolt OD in both pieces. If it is, the strut wont move.
                            What do you mean you went from 3/16 to .187 Howard. 3/16 IS .187
                            www.keithbradleyboats.com
                            • Howard Lee
                              • Nov 2010
                              • 202
                              #419
                              .150 to 3/16 shaft and then when to .187 to 3/16 shaft sorry about that.
                              • Howard Lee
                                • Nov 2010
                                • 202
                                #420
                                If you put grooves in your strut you wont need another bolt. The genesis has only 1 bolt but with grooves in the strut plate and it has never moved.
