mean machine finally getting finished
  • ls1fst98
    • 905
    looking at batteries tonight and i guess i need something bigger than a 5000mah 20c?? i have these in 2s and was hoping to be able to get a pair of 3s same mah and c rating to run 5s, but i guess i need to get these instead so i dont over draw the batteries.
    http://hobbyking.com/hobbyking/store...dProduct=15020
    • forescott
      Hopelessly Addicted to RC
      • 3009
      30c packs should provide more than enough amps for the outrunner. I don't like the 8ga wire that comes on the 40c packs. It's super stiff and harder to solder.
      • ls1fst98
        • 905
        so the 20c would be out of the question though? like i said only reason id like to stick with that is my 2s are 20-30c and if i could get the same in 3s then i can run it on 5s and even run my sv27 on 5s.
        also what size are the bullets on the t600? i tried to look it up and can not find that info anywhere.
        • forescott
          • 3009
          They may work ok. !00amps is what they will produce. The outrunner will probably pull right around 100 amps. A higher c-rating would be better. But 20c packs aew cheap and if you have another hull to use them in I would give it a try. If your batteries come in hot, then you know they arent producing enough amps.
          • ls1fst98
            • 905
            my camera is having issues, so far heres all the pics i can get of it loaded to my computer. it is pretty much done except for a final sanding ont he transom where i patched some old holes. just need to figure out a good way to seal up the stock hatch until i can make one and go make a test run.
