Warning: Trying to access array offset on null in phar://.../vb/vb.phar/bbcode/url.php on line 2 mean machine finally getting finished - RcBoaters Forum
  • ls1fst98
    • 905
    heres my mean machine that i got as a flood hull, bought a speedmaster strut, watercooled motor mount and a UL1, but after some looking ive decided to use one of my turnigy 600 outrunners. its a 1400kv motor. any advice on prop sizes to start with will be greatly appreciated. also, since i have through hull water pickups, what is a good rudder without pickup.
    heres a few shots so far.
    thinking swordfish 120 or turnigy 125a esc. and 6s
  • DISAR
    • 1137
    Good choice. I run my mean machine with the T600 1400kv motor on 5-6s (also tested the Scorpion 4025 1470kv and performance is same).
    I use the 445 on 6s and the 646/3 on 5s all with the turnigy 180. I have tested many props but these worked best for me. Max amps were 140A on 6s with the 445.
    (I do not recommend these 120A escs on 6s)
    http://www.rcfastboats.com/
    • ls1fst98
      • 905
      do you run a thrust bearing on that outrunner? i think im going to use the suppo 200a esc and a receiver pack i have for my rc car and run it on 5 or 6s depending on how the water is. im trying to find a good rudder with no water pickup since i have two, dual through hull pick ups.
      • ls1fst98
        • 905
        and what is the equivalent of the 445 in a carbon prop? since i do not know how to sharpen or balance a prop and would like to get one cheap for tuning and checking the setup?
        • ls1fst98
          • 905
          sorry i found i think
          http://www.offshoreelectrics.com/pro...od=grp-2317.45
          • NativePaul
            Greased Weasel
            • 2770
            This is the Graupner 445 with 3/16 dog drive, if you are referring to the Octura X445 however you should realise that although both are 45mm diameter with 1.4 pitch ratio the blade shapes are very different and a stock B/S/P Octura of the same size will pull more amps than the Graupner so don't push things to the limit with a Graupner prop then replace it with the same size Octura.
            • ls1fst98
              • 905
              ok, thanks for the info native! much appreciated. I ordered the graupner just to get going. im hoping that with the 200amp esc ill have some room to play with. but i will def keep an eye on things. on average whats a good running temp for the 1400kv outrunner on 6s?
              • DISAR
                • 1137
                mine is about 155F max., no thrust bearing. In general I've heard that outrunners can sustain high temps, like 180F but no experience on this
                • ls1fst98
                  • 905
                  yea idk i want to push it to that temp, esp seeing as its a fairly cheap motor. but its good info to have. i ordered a thrust bearing for mine seeing as the only thing that seems to hold teh shaft in place is the little clip on the front of the motor.
                  • ls1fst98
                    • 905
                    Motor mount modified to fit the larger screws of the 600 outrunner, and installed the pickups for cooling. Removed the autobailers, idk if this was wise or not. My package from OSE should be here in the next two days or so. Love ordering from here, things always arrive quickly.
                    Next question, should I run two 3s packs or is there room to run two 6s packs or 4 3s packs? To double the aH?
                    • ls1fst98
                      • 905
                      removed hardware to plug up holes in teh transom. got my suppo 200a esc in, going to figure out where to mount it. Where is a good CG poing on these?
                      DISAR, what kind of speeds do you see with that outrunner?
                      • DISAR
                        • 1137
                        on 6s with a 445, 48 mph on sea water (always some chop). can try for more but handling on the chop is my issue.
                        You can place the esc forward of the motor, why so many water inlets?
                        I don't have the boat with me right now but I think I have the cg as in the photo moving slightly forward or aft depending on water conditions.
                        • ls1fst98
                          • 905
                          Well the reason for the four inlets was I was going to run it in an inrunner with a jacket. So I wanted one for the motor, one for the mount, one for the esc, and then one for something else. Overkill....possibly. Now I was thinking of using two for mount and two for esc, one from each side so if one sponson came out of the water, I would still have flow. Or I can pull one side out if it's not going to work. Was just me thinking of over doing it I guess
                          • forescott
                            Hopelessly Addicted to RC
                            • 3009
                            You can "Y" 2 of them into the motor mount and "Y" the other 2 into the esc.
                            • ls1fst98
                              • 905
                              Yea that was the plan now. One from each side of the boat. Sure it might be overkill but....oh well. They were cheap and if I upgrade to a twin in this or some other setup they are already there
