dereks ekos
  • derektheshop
    go over board
    • 63
    #46
    the paint is finished
    so finally finished with the never ending paint job, needless to say i am very happy with how she came out. I am equally exited to start taking evereything out of the inside of this thing and lay the orange and black carbon fiber down and start the reconfiguration of electronics... just wait till you see the trick water outlets i found at toughracing.com
    derek
    • derektheshop
      go over board
      • 63
      #47
      today i stripped the inside of the boat out.. i am going to lay out the carbon fiber tomorow and wednesday
      derek
      • derektheshop
        go over board
        • 63
        #48
        so tonight i layed the carbon fiber out..not easy by any means but think it came out pretty good for my first time... this thing is as strong as its gonna get. as soon as the fiberglass is set i am going to start wet sanding and buffing i now see what you guys say about keep your edges sharp, the clear rolled over the edges pretty good.. no biggie just have some fine sanding to do
        derek
        • bigpapa
          • Apr 2009
          • 2531
          #49
          looks great
          THUNDER TIGER OUTLAW,THUNDER TIGER BANDIT
          CARBON FIBER MINICAT HYDRO,MINICAT HYDRO,PROBOAT MISS GEICO,SKUNKWORKS 32" CAT TWIN, H@M VIPER TURBINE ---JEFF WOHLT WIRE DRIVES
          • LarrysDrifter
            Big Booty Daddy
            • May 2010
            • 3416
            #50
            Shes looking good Derek.Another tip that I would do if I were doing an EKOS again is to remove the stock flotation foam from the front and use Great Stuff Window and Door expanding foam in its place.Others may be against this type of foam,but it works if your careful and use small amounts at a time.There are other foams out there that may be better for FE use,but I dont think its cheap.
            Another tip,remove the stock windshield and use something else in its place or fill the window openings.The windows will blow out,flooding the inside of the boat.
            • JPriami
              N4FOX
              • 1711
              #51
              looking good. whats the weight increase with all that work done? did you weight the hull before you started?
              • ScarabChris
                • Oct 2010
                • 812
                #52
                I'm pretty sure I know what outlets you are talking about. I just got a few myself.
                Looking good by the way.
                • derektheshop
                  go over board
                  • 63
                  #53
                  i didn t weight it before i started but with some searching im sure i could find out, i am interested to see how much heavier it is now by holding it i can feel a difference since it put the carbon fiber in but in the paint stages i didnt notice. its only logical that i gained with 7 stages of paint. i test fitted the outlets today and they look great, got some soldering to do tonight on the 9xl's and fit the jackets
                  derek
                  • derektheshop
                    go over board
                    • 63
                    #54
                    today i mounted the motors, in order to do so i had to boar out the stock mounts so the collets would fit through with ease.. then i took out the stock foam in the bow of the boat and shot some GREAT STUFF in there very nice expanding nicely. i also mounted the rear water outlets where you used to find the cheesy exaust pipes, much nicer and serves a purposehere some pics
                    derek
                    • derektheshop
                      go over board
                      • 63
                      #55
                      thanks
                      got the outlets mounted today they look great, what are you putting your s on
                      derek
                      • derektheshop
                        go over board
                        • 63
                        #56
                        so im held up for the moment i am waiting for my escs and for some reason the wire drives that everyone is runnung in this boat wont fit in mine without me finding a bearing that would fit the stub shaft on the wire drive... with some searching i found some dynamite 5x7 bearing, as soon as they get here i can finish this boat and bench test it. i have since weighed her and she comes in at just under 5 lbs with packs in minus the esc's
                        derek
                        • forescott
                          Hopelessly Addicted to RC
                          • 3009
                          #57
                          Interesting..... They should slide right in. Did you get them from rcraceboat.com?
                          • ScarabChris
                            • Oct 2010
                            • 812
                            #58
                            If they ever show up I am going to put them on a scale build. Its a 50" Apache with scale Merc style outdrives. The water outlets will double as scale exhaust pipes.
                            • derektheshop
                              go over board
                              • 63
                              #59
                              ya i ordered the wrong ones i got the ones from OSE but i ordered the ones from rcraceboat.com. lastnight so pretty much almost squared away here... and the water outlets took forever to get to me to well worth it when you get them stick the end in a drill and take some metal polish in a rag and drill away they polish up like a mirror...
                              derek
                              • derektheshop
                                go over board
                                • 63
                                #60
                                so here it is complete and ready to go...let me tell you this thing is a tank strong smooth and completely crazy looking... after the long 45 day wait on the turnigy escs i plugged in the batterys and wow this thing is gonna move. ill get some videos posted asap
                                derek
