Larrys 32" twin cat
  • FighterCat57
    "The" Fighter Cat
    • Apr 2010
    • 3784
    #106
    Originally posted by johnson22456 View Post
    Well Larry is finally happy with the performance of this boat, Bob and I have been happy with it for some time now, but Larry wanted more. He got more today, and here's the video to prove it.
    Wow, nice! Well done Larry!
    • nikos222
      • Jan 2010
      • 25
      #107
      It's a really good job.
      I think that this boat can catch the 80mph easily !!!
      That's my sense.
      • rchuntlsl
        • 122
        #108
        Looks like Larry has about $75 to spend on tougher stingers. Ekos parts not hacking it. That thing scoots!! Nice build.
        • LarrysDrifter
          Big Booty Daddy
          • 3416
          #109
          Im currently working on converting my EKOS stingers to 3/16. Still going to run the .078 wire drives. I also bought a replacement 3 blade prop for Eric. Ill be using these again in a bigger pond soon to see if I can hit 80mph-in a 4s powered cat. The reason I lost a prop in the last video is the Locktite let go that holds the wire in the stub shaft. We have since bought new Locktite,only realizing after the fact that it does indeed have an expiration date.
          Thank you all for the compliments.Makes me want to go faster yet.
          Another thing,please dont post any GPS spectulations-I just go by my GPS for my speed report. I dont care how accurate it is or not. Its what I go by for my personal use and reference.
          • Jeff Wohlt
            • 2740
            #110
            Drill a hole in the stub and then put a flat spot on the wire then loctite it in and set your drive dog set screw down on the wire flat. I make these for super power and never have had one come apart.
            Was that mine that let go or your own since you mentioned loctite date.
            ...sounds hard but I have it down and works great.
            www.rcraceboat.com
            jwohlt5362@yahoo.com
            • LarrysDrifter
              Big Booty Daddy
              • 3416
              #111
              It was your stub that you made me a while back for .062 wire,but I had drilled it out to accept .078 wire.So,you did not make this last one for me.It was my doing. I just got done converting one stinger to 3/16.Ill finish the other tomorrow. That sounds like a good idea,Jeff. I might do that before I get both stingers completely assembled.Thanks for the tip.
                This I would like to see a picture of. Do you sell them like that Jeff?
                • mike76
                  • Dec 2008
                  • 120
                  #113
                  hi Larry
                  very nice performance!
                  and good job so how long is your run with 4S ?
                  • Jeff Wohlt
                    • 2740
                    #114
                    Yes I do but not on my site. Works very well...I only make them for special apps or requested.
                    www.rcraceboat.com
                    • LarrysDrifter
                      Big Booty Daddy
                      • 3416
                      #115
                      Originally posted by mike76 View Post
                      hi Larry
                      Ive never actually timed it. Running 4s with the 442's, I would guess about 5-6 minutes.With these props,I usually run it untill LVC or right near it.
                      • LarrysDrifter
                        Big Booty Daddy
                        • 3416
                        #116
                        I ran the boat today with the ABC props. Heated my Turnigy 4000mah 30-40c packs a bit and ran 79mph. These are older packs with quit a few cycles on them. This run lasted maybe 2 minutes.I didnt time the run. Next,I ran 4 of Johnsons 2s 5000mah 40-50c packs that have been in the warmer for a good while. I ran 81.4mph. I still havent bought a battery for my temp gun yet,so I dont know the temp of the batteries,but I know they werent 100 degrees. This run was just over a minute. I also cant give temps on the components,but I could stand there all day with my finger on the shaft of the Arc motors and the SeaKing 120's. I dont see why more FE boaters dont use Arc motors-they are extremely tough and put out awesome power. They dont make 40mm motors,only 380 and 540 size. They also make a 20mm.Id like to find some detailed specs on the Arcs,but cant find any.www.lightflightrc.com only gives a small amount and thats only on certain motors.Im going to do some prop work to the ABC's and heat the batteries up more next time. Im very confident I can easily hit 85mph....on 4s.
                        • JPriami
                          N4FOX
                          • 1711
                          #117
                          Hell yeah! Go Larry! Nice job on 4S!
                          • Jacked1
                            • Jun 2010
                            • 787
                            #118
                            Good Job!
                            • johnson22456
                              Counting down the days...
                              • 228
                              #119
                              81mph on the one day I didn't have the camera in my toolbox.
                              Sure was moving, and no props were lost.
                              Im jealous.
                              Hpr 115, Neu 1521 1.5d x2. Delta force Pirate, Insane 45" Neu 2230
                              • Rumdog
                                • 6667
                                #120
                                Sweet!
                                Which ABC props did you use?
