Larrys 32" twin cat
  • LarrysDrifter
    Big Booty Daddy
    • 3278
    Larrys 32" twin cat
    Heres my new 32" FighterCat pre-painted hull.Im running 2 Arc 36x55 2800kv motors on 4s with 120 amp SeaKings.All hardware will be from my recently retired EKOS.
    First thing to do is re-inforcement as the stock hull is very thin.Im using fiberglass matting and resin and will go 2 layers thick on the floor and sponson bottoms and sides for the seam.These pics show the stock hull.
  • blackcat26
    High Speed Junkie
    • Sep 2009
    • 1598
    I don't know Larry you sure are busy. Maybe you should sell me that Daytona so you can focus more on this one......
    • LarrysDrifter
      Big Booty Daddy
      • 3278
      This is the matting that went into the hull for the 1st layer.Im going to let this cure untill tomorrow evening when I put the 2nd layer in.I have to make this thing a tank because I know it ll be going air borne.
      • LarrysDrifter
        Big Booty Daddy
        • 3278
        I might have to if I cant get the stingers,but they should be one the way soon.Hopefully I can get this one done before the stingers for the triple come in.Should be able to-I have all the parts.Maybe you should do a quad drive BlackCat.
        • blackcat26
          High Speed Junkie
          • Sep 2009
          • 1598
          Nah twins are pain in the rear enough for me! Next I think is a prince 25 twin.
          • LarrysDrifter
            Big Booty Daddy
            • 3278
            That d be sweet.Are you working on anything right now?
            • blackcat26
              High Speed Junkie
              • Sep 2009
              • 1598
              Got a thundercat twin to build but not really that motivated yet.
              • LarrysDrifter
                Big Booty Daddy
                • 3278
                Im forcing myself to re-inforce this one.This is the one thing I dont enjoy so much,but it has to be done.And the water here is freezing quick too,so its not like I can run it soon.
                • LarrysDrifter
                  Big Booty Daddy
                  • 3278
                  Got the sides re-inforced a bit ago.Now it all has 1 layer in it.One more layer to go.No use taking pics of the re-re-incoforcement.
                  • keithbradley
                    • 3663
                    Sweet
                    Those motors on 4s should scream...any thoughts on what props you are starting with?
                    Looking forward to following the build
                    www.keithbradleyboats.com
                    • LarrysDrifter
                      Big Booty Daddy
                      • 3278
                      Prob end up with 442's.starting with 36's.
                      • LarrysDrifter
                        Big Booty Daddy
                        • 3278
                        Heres the last layer of re-inforcement.Turned out nice and smooth.The FG goes to about the Cats "chin" on the deck.I couldnt get it any further.Tomorrow,Ill pick up some Great Stuff window and door foam for floatation and a little more strength in the bow and will seal it up with epoxy to water proof it.
                        • LarrysDrifter
                          Big Booty Daddy
                          • 3278
                          This is my set up.Two Arc 2800's and two SeaKing 120's on 4s.Should scoot pretty fast and run nice and cool.The stingers are from my retired EKOS hull and still retain the 4mm stub shafts.Steering is a Speedmaster mini hydro offset rudder.This hull will also have floor pickup water cooling as well.I hate seeing silicone tubing on the outside of my boats.
                            • 9479
                            interested to see how she runs with that much rpm
                            • LarrysDrifter
                              Big Booty Daddy
                              • 3278
                              Me too.Its 41,440rpm.I might have to get two more x442's and have them cut down to 40mm.I dont really want this to become a SAW boat,so,if it does,Ill sell the Arcs and get a couple Leopards like you are in a lesser kv,like 2650.Oh,I do have two TFL 38mmx55mm counter props from kintec that I can use too.
