54" Scarab Hull - Trip or Quad Outboards
  • PlayinHookySPI
    • Nov 2010
    • 34
    Its been a slow process building this boat. I have built a bracket and mounted the 3 motors to it and attached to the boat. Also have a deck ready to be glassed in, just havnt had enough time in the past few months to do so since fishing season started. Ill post pictures of what i have done as soon as i can get them from my office.
    Need some Wiring and Battery help.
    What i have so far is 3 Turnigy marine 60A ESCs and 3 Turnigy B36-56-06 1800kv motors mounted in the outboards. The batteries will be mounted way up front and the ESCs somewhere in the middle. I need to extend the wiring to connect everything together. What kind and gauge wire should i use to connect everything?
    Also what size batteries should i use to run each motor? I was thinking about a 4s in the 3000-4000mAh size but i dont know what C rating to get?
    I need to make sure things done get to hot under the hatch.
    Any help would be greatly appreciated.
    Capt Jeff
    • PlayinHookySPI
      • Nov 2010
      • 34
      • PlayinHookySPI
        • Nov 2010
        • 34
        • PlayinHookySPI
          • Nov 2010
          • 34
          • Jacked1
            • Jun 2010
            • 787
            That is pretty sweet!!!
            The title for this build is very similar to mine.
            If you are planning on running one batt per esc some 4000mah 30c batts would do great. But I suggest getting some 5000mah batts for longer run times.
            I would suggest putting the batts really far forward so you can get a good cog with all that weight off the back of the boat.
            Fleet: 55" Quad inline T600 Cigarette boat, Twin Mean Machine, Twin T600 47" mystery mono, 4082 Surge Crusher, 1717 8s Genesis, 4074 Villain, "mini mono", 52" Bonzi, Prather Funcruiser, 2 DPI 3.5cc tunnels, 5' Styrofoam recover barge
              • 6057
              Thats so cool!
                • 9481
                I agree, very cool man!
                • Boaterguy
                  • 1779
                  this thing will purr! but the COG will be wayyyy back with those motors hanging off
                  • Arctic Fire
                    • 84
                    Absolutley awesome dude, Can't wait to see it with the hull painted and Donzi decals!
                    • Jedi Master
                      • 242
                      What a great build, can't wait to see it running!!!
                      Do or do not, there is no try!!!!!
                      Aeromarine Titan 29 H&M Hawaii Kai III Proboat Stiletto ML Boatworks PS295 (No.8)
                      • PapaGriz
                        Scale OSFE Rookie
                        • Jul 2011
                        • 87
                        This is inspirational to say the least!! Can't wait to see this come together.
                        Great stuff.
                        • Steven Vaccaro
                          Administrator
                          • 8932
                          very cool. I would put some triangle type brackets inside and on the transom to help keep the transom from flexing.
                          Steven Vaccaro
                          • PlayinHookySPI
                            • Nov 2010
                            • 34
                            Laying up the Deck. 1/8" Hobby Ply and 2 layers of Glass on each side.
                            Uncovered
                            Ready to trim.
                            Fits like a glove.
                            • PlayinHookySPI
                              • Nov 2010
                              • 34
                              Starting the Console.
                              Done for now.
                              • PlayinHookySPI
                                • Nov 2010
                                • 34
                                Starting the elevated removeable under deck platform.
