54" Scarab Hull - Trip or Quad Outboards
  • PlayinHookySPI
    • Nov 2010
    • 34
    #46
    ESC mounts made and strapped down.
    Plumbed through the lower deck. Will be concealed under the deck also.
    Through deck view with T fitting.
    • PlayinHookySPI
      • Nov 2010
      • 34
      #47
      3 way splitter made to connect all 3 ESCs.
      Side reliefs cut into the sides to match the Donzi 38 ZF.
      Templates glued to the floor to support the vertical walls.
      Additional support.
      • PlayinHookySPI
        • Nov 2010
        • 34
        #48
        To make the tight compound curves. I took some of the 3/16 balsa im using for the vertical sides
        and cut it into 1/8" strips. Lined them all back up and taped them together to make a very flexible
        structure to make the tight curves.
        Taped on the back.
        Curves installed.
        The gaps in the curves will be filled in with either wood filler or bondo and sanded smooth.
        • PlayinHookySPI
          • Nov 2010
          • 34
          #49
          The beginning of the transom.
          Made a door through the glass hull.
          • PlayinHookySPI
            • Nov 2010
            • 34
            #50
            Some finish sanding and rounding of all corners will be done later on.
            Next is finishing the Gunnels, and then back to the console and then
            going to try brazzing up the T-Top supports with a solid top.
            More to come soon.
            • Boaterguy
              • 1779
              #51
              two servos controlling three outboards? is the center one just liked to the outer two which are attached to servos?
              I like the clean look of the tubes going through the hull
              • PlayinHookySPI
                • Nov 2010
                • 34
                #52
                I plan on connecting both servos to the center motor. One off of each end of the motor arm.
                Then i will make some tie-bars to connect the outter motors to the center motor.
                Im going to remake the servo tray out of something stronger than the balsa i have it made out of now.
                It was just for mochup.
                Hope it works.
                • Make-a-Wake
                  FE Rules!
                  • 6057
                  #53
                  This is a very nice build..........................great work, love the scalers!!!
                    The rear transom is looking really great.
                    • Arctic Fire
                      • 84
                      #55
                      Looking awesome, keep us posted
                      • Gimp
                        I am the Stig
                        • 547
                        #56
                        Any updates on this awesome boat?
                        -Fighter Cat Racing-
                        • PlayinHookySPI
                          • Nov 2010
                          • 34
                          #57
                          I wish i had more to post but shortly after i made my last post, i lost interest in the project. Started working on a couple planes and my full size boats.
                          Its still sitting right above my TV so i look at it everyday. Hope to get back on it soon.
                          We have had a very mild winter down here so ive been out and about a lot, fishing and flying rc planes.
                          Ill finish it, i promise.
                          • Gimp
                            I am the Stig
                            • 547
                            #58
                            I hope you do, this is an awesome build
                            • Make-a-Wake
                              FE Rules!
                              • 6057
                              #59
                              Yes, please do.....................what made you lose interest, just curious?
                              • Eodman
                                • 1285
                                #60
                                When you get your interest back ask a couple of the more experienced builders here about running Brushless motors at half speed. You have done an outstanding job on this and I would hate to see your electrics go poof and burn this pretty baby down!
                                Seems to me that i remember reading that at half throttle there is a tremendous about heat build up but not sure!
                                We did it with a Bang!
                                Cats Are Where It's At!
