What to do with this old CAT?
  • Rich
    • 581
    I was cleaning out the basement and came across my first electric boat...yes I said first Electric Boat! Anyway, it originally had twin 550 can motors geared to one prop with a steerable strut. It measures 29.5" by 10" and is made out of abs plastic. I was reading forescott's twin outboard build and it wasn't long to make the jump that this old cat needs an outboard. The proboat outboard is what I plan to use.
    Problems:
    1. The seam where the two halves of the hull would get in the way of mounting the outboard, any ideas there?
    2. The old drive shaft has a molded outlet on the bottom, this would cause massive cavitation problems, should I grind it off and seal it? or could I just lower the motor?
    3. What motor should I use? and what prop? I'm not looking to break any speed records with this one, just want to give it life. Ok ....Maybe in the low 40's
    Here are some Pics:
  • drwayne
    • 3012
    put it back in the basement !
    • Brushlessracev
      • Oct 2010
      • 154
      Make a good recovery boat.
      • Rich
        • 581
        ok I'm not going to lie that was funny!
        Brushlessracev...a recovery boat? That's a good idea I think ill do that!
        • Brushlessracev
          • Oct 2010
          • 154
          I purchased a $30.00 boat on ebay works great.
          • dana
            • Mar 2010
            • 3660
            make it a recovery boat
            • Make-a-Wake
              FE Rules!
              • 6057
              I'd sure be tempted to throw the Proboat OB on it and run it with mild brushless.
              • domwilson
                • 4411
                Here is an interesting thread... http://www.rcuniverse.com/forum/m_31...tm.htm#6615142
                Government Moto:
                • Rich
                  • 581
                  So we got recovery boat as an option, but I use a fishing rod for recovery. And I have one for the OB option...hmm I like both ideas, but it would suck to bring two boats to the lake and have only run one for recovery. I am still leaning toward the mild brushless OB though. I just don't know what setup I should go with? UL-1 motor on 2s? maybe?
                  • Make-a-Wake
                    FE Rules!
                    • 6057
                    This is actually a bit higher than the mild, but the PB can handle it. Its a Leopard 36x60mm motor. The PB outboard has 56mm length motor in it but the wires come out the top of the motor. These wires come out the side.......it should be a perfect fit. I'd go 4s with it.
                    http://cgi.ebay.com/rc-boat-hi-power...b0d21&x=41&y=4
                    • Brushlessracev
                      • Oct 2010
                      • 154
                      I am looking at putting one of them in my Miss Vegas build.
                      • domwilson
                        • 4411
                        Is the ABS brittle? Maybe for ease of build, go with a proboat motor inboard on 4s?
                        Government Moto:
                        • Rich
                          • 581
                          I like leopard motors they work awesome! Got to see if I can get my hands on one!
                          That's a good question I'll have to see what shape the hull is in...
