OSE Brothers Outlaw
    • 9479
    Originally posted by Jpope View Post
    due you think a NEU 2215/2y or a 1527/2y would push this hull? just picking your brain on other options
    you would need a good amount of volts to get them running decent rpms
      • 9479
      Ok I decided to take more out of this hull to clean it up some
      the stock 60amp esc that came in this boat, I'm going to use in the 16.5" JAE Rigger
      took the tray out.. now I need a sweet looking servo mount
      • Jpope
        • Feb 2011
        • 30
        keep it going brushless, i gutted miine same as you did. Haven't made up my mind yet on power plant just yet.
        • chummer
          • 636
          Just notch out the stringer and mount the servo. It looks like your rudder push rod will line right up.
          "IT IS BETTER TO REMAIN SILENT AND THOUGHT A FOOL THAN TO OPEN YOUR MOUTH AND REMOVE ALL DOUBT"
            • 9479
            #35
            Great call Roger!
            next.. what do I do about building up the stringer, as the stringer was cut to fit the plastic motor mount from Thundertiger??
            • chummer
              • 636
              #36
              Brushless, Did you think about moving the motor to the back and putting your batteries forward. Could make a sweet layout. Worth a try. The stuffing tube looks like it would be easy enough to remove.
                • 9479
                #37
                Ok I get ya.
                How far back to you think the motor should set, or how close to the transom should I put it?
                ideas??
                another good one man!
                • chummer
                  • 636
                  #38
                  Ok I get ya.
                  ideas??
                  I honestly don't have a clue without ever touching that hull. I am waiting on a HK Vanquish then I will know better, I think they are very close to the same hull.
                  Try moving the motor back far enough and keep it low enough that you can still make a smooth gradual bend in the stuffing tube. I would move as far back as you can but make sure to leave plenty of room to loosen the coupler.
                  Make a nice battery tray between the stringers for 6S 2P. Try to mock it up and see how the COG works out. I would make sure that you can always get 27% to 33% just by sliding the batteries forward. That way you have your ass covered for all different running conditions. Nice and loose or choppy water.
                    • 9479
                    #39
                    I'll get some things mocked up in a couple hours and get a better idea for the both of us
                    I do like the battery tray in the hull you are getting.. lots of room for big batteries and slots for velcro straps
                    • chummer
                      • 636
                      #40
                      I will gut that hull when I get it. I plan on using 4" stringers in it. It will help keep the bottom of the hull from flexing. You should be able to fit a nice plate between your stringers and run 6S 2P. I wish I had some pics of my old DF layout. I am building another one though, I should have it back together in a couple of weeks.
                        • 9479
                        #41
                        WOW!
                        it's been over a year
                        lets get this baby rolling!!
                        ok a little mock up.. not sure where the sweet spot is, but with 6s2p this is about 26-27%
                        any and all who want to give ideas, I'm all ears
                          • 7651
                          #42
                          I like the idea of using the batteries to adjust the CG.My DF 35" has the motor up forward and I have to run split packs.It has like no freeboard though.Do you think an 180 will keep up?
                          • Rumdog
                            • 6453
                            #43
                            Motor as far back as you can get it and still easily get to the collet. Batteries front and center.
                              • 9479
                              #44
                              yes, a few have run the T180 with great results...
                              but... I want to run 8s on this once and a while, so I'll need a different esc for that
                              I give this a try in mock up..
                              • CHUD
                                • 497
                                #45
                                Hay brushless how's the flex shaft going to take being that short,and are ya going to move up to A 187 flex or is the standerd 150 going to be O,K
