Twin outboard center console build
  • ScarabChris
    • Oct 2010
    • 812
    #46
    Counter rotating props and trim tabs....
    Charging batteries and will do a test run. These props are 2 mm larger in diameter so I'm not sure how it will run.
    • ScarabChris
      • Oct 2010
      • 812
      #47
      OK I did a test run and its obvious these props are too much for these motors. Right away I can tell by the sound they make that they are loading up too much and the boat was slightly slower. The motors got hot and had that "smell" after just a few minutes of run.
      The original 2 blade props are 1.25" diameter (not sure of the pitch) and these new 3 blade props are 1.5" (36mm) diameter and 1.4 pitch.
      Anyone have a suggestion for props? I was counter rotating 3 blade cleaver props to keep with the scale theme. Or maybe some stronger motors? But then the gear will be the weak link. What a dilemma.
      Also....the motors are filling with water, not good. But the hoses might have been lose so I'll have to test that again.
      The upside is the trim tabs leveled the boat right out.
      • ScarabChris
        • Oct 2010
        • 812
        #48
        Damn, hoses are tight on the cooling coil and the motor cowlings are still filling up. And whats happening is the motors are sucking the water up and blowing it out the tops. They won't last long like that.
        • Darin Jordan
          • 9446
          #49
          My experience with these outboards and those brushed motors (are you running the stock silver canned motors???) is that they are kind of "draggy" and use a lot of power to turn the prop. Any more prop than an X435 or so is really going to be pushing things. I played around with one of these on the original AQ Bass Boat and the brushed setups just go really hot, and really didn't deliver the performance I was after.
          Do you know what pitch those 3-blade props are that you have on there??
          You might have better luck, if you want to stay with those outboards, if you switched over to a suitable Brushless 1/10th scale sized car/truck motor. Something like a 17.5 or 13.5 T would deliver much more torque than the 550 can motors would, and should bolt right on.
          Darin E. Jordan - Renton, WA
          • ScarabChris
            • Oct 2010
            • 812
            #50
            Originally posted by RayR
            Chris,
            What dimensions do you want these decals?
            All the best,
            Ray
            Dude if you cam make them with the "Evinrude" 2 inches long and the rest proportionate that would be awsome!
            Let me know if you can find "Scarab Sport" too! I looked all over the internet and all I could find was just "Scarab"
            • ScarabChris
              • Oct 2010
              • 812
              #51
              The pitch on these 3 blades is 1.4 which appears to be identical to the stock 2 blades. The only difference seems to be the extra 2 mm in diameter and the extra blade.
              I just ordered some 3 blades with the same diameter and pitch as the stock 2 blades. We will see if they are better.
              The motors....well I can see with these outboards the weak point is the lower unit gears. They seem impossible to get without buying an entire new motor for 75 bucks. So I don't think putting more power on those gears is a good idea.
              I just got my 7 cell Ni-MH batteries so the boat will be going a little slower anyway. These batteries are much heavier than the LiPo's and less volts. 8.4 as opposed to 12 volts for the LiPos.
              BTW....should these Ni-Mh battery packs get warm when charging? I charged them right out of the package. Hopefully didn't over charge them.
              • ScarabChris
                • Oct 2010
                • 812
                #52
                Oh and the water was getting into the motor cowlings through the seem where the cover meets the lower cowling. I put tape around it and no water.
                • Darin Jordan
                  • 9446
                  #53
                  So, 1.4 sounds more like the pitch ratio than the actual pitch... Take the Pitch Ratio (1.4) and multiply it times the diameter to get the actual pitch.
                  That might help. If you could give the exact specs of the props, we might be able to help more.
                  That might be the case... I had a couple of these and the gears do get worn quickly. The real weak point is the stub-shaft, which is only 3mm and bends pretty easily.
                  If you decide that these units won't cut it, you can spend a few more $$ and get a VERY solid, and fairly scale looking unit from ProBoat:
                  This unit will take ALL the power you can throw at it and can handle some serious prop as well...
                  That should help too... It does sound like you were turning those motors too hard for the application and pitch of the props.
                  Yes... when they reach their peak cut-off, they'll be warm... often around 120-degrees or more, depending on the cells...
                  • forescott
                    Hopelessly Addicted to RC
                    • 3009
                    #54
                    What props did you end up with? Venom sells 32mm 3-blade aluminum counter rotating props that have a very scale appearance. They are fit a 4mm shaft.
                    • ScarabChris
                      • Oct 2010
                      • 812
                      #55
                      Darin, thanks for all the info, maybe I'll look into those Pro Boat motors if these don't hold up.
                      Scott, Yes, those are the props I ordered. The 3 blades I have pictured above are Venom 36 mm but the plastic ones. Going from a 3 mm shaft to a 4 mm is easy, heat shrink the shaft until the prop fits snug.
                      • Make-a-Wake
                        FE Rules!
                        • 6057
                        #56
                        Try running these motors on 7 cells for more torque(stock motors are 27t)...............you can probably use the nice 36mm 3-blades with them.............i was considering them for my EP-1's til i went brushless
                        http://www3.towerhobbies.com/cgi-bin...?&I=LXWYE2&P=7
                        The build looks very nice!
                        • ScarabChris
                          • Oct 2010
                          • 812
                          #57
                          Should bolt right up?
                          Though at this point I think my problem will be with the gears in the lower unit. I don't want to strap anymore power to the top end without knowing I can get replacement gears for the bottom end. On the hunt for the gears now. May have tracked down one set from a guy on RC Groups.
                          • Make-a-Wake
                            FE Rules!
                            • 6057
                            #58
                            Yeah, thats me...................i'll look for them
                            The 35t motors arent more "powerful" per say...............they have a lower rpm and are a bit more torquey.
                            • ScarabChris
                              • Oct 2010
                              • 812
                              #59
                              Yeah more torquey, the enemy of weak gears. I know this from dealing with real boats. I have blown a few lower units on my real boats.
                              I really like the scale look of these EP1s so I want to try and make them work. I was thinking of having a place like this make them for me out of stainless steel.http://www.rushgears.com/?referrer=G...FSNj7AodkB2lPQ
                              Though it will probably cost a fortune, could probably buy a crate of EP1s for what the tooling costs would be.
                              • Make-a-Wake
                                FE Rules!
                                • 6057
                                #60
                                I called that exact place one time to get ONE delryn gear made for a vintage Nikko truck, and they wanted to charge me like a grand or something ridiculous.
                                I havent found the pack of two new gears i thought i had yet, but if you want i'll send you the two outboards that have 4 gears in them that seem decent still.....they arent new but dont look too bad..........one outboard is cracked on the lower unit, there are two cowls and two of those coupler gears. One shaft wont come out for me. They will never be used by me again so no biggie.
