Project Sprintcat! FighterCat Goes Ligit!
  • LarrysDrifter
    Big Booty Daddy
    • May 2010
    • 3278
    Sorry for jacking your thread Ben.I just realized what I was doing.Brain fart.
    • FighterCat57
      "The" Fighter Cat
      • Apr 2010
      • 3480
      Still planning on Twin 4030 1400kv outrunners on 6s.
      The big question is... Hydra 240 or Seaking 180?
      I'm also thinking I should figure out a good Lipo strategy. 4x 3s 5k 45c?
      • Rumdog
        • 6453
        Seaking will prob be more reliable on 6s. I run 1p per motor in my twins. Your setup should work well. I'll be running single 6s1p 30c 5000mah per side on my current build.
        • H2OCamel
          FAST ELECTRIC EVERYTHING
          • Oct 2007
          • 484
          here is the wrap thread:
          "Discussion is an exchange of knowledge; an argument, an exchange of ignorance." Robert Quillen
          • JMSCARD
            • Mar 2010
            • 3444
            I agree... I have 5 of em... actually now 6 since I aquired another in a woodstuff tunnel I bought from mike... and the seaking/turnigy 180's are very reliable...
            • johnf
              • Dec 2009
              • 1078
              Hey Ben, did you get this straight from Aeromarine? Is it the 36 inch version?
              Thanks
              Catching Air!
              • FighterCat57
                "The" Fighter Cat
                • Apr 2010
                • 3480
                Thanks
                Yeah, it's the 36" hull
                • Rumdog
                  • 6453
                  How is she coming, Ben?
                  • FighterCat57
                    "The" Fighter Cat
                    • Apr 2010
                    • 3480
                    You reading my mind or something?
                    I just got the bench setup and the epoxy is drying on the motor mounts!
                    I'm going to go with twin 1717's, Hydra 240's and try for 450/3 L & R on 6s2p
                    F- the water cooling on the motors. I have two 40mm 12cfm fans I'm mounting on them.
                    That's almost enough air to make it a HOVERCRAFT!
                    I was thinking about drilling the motors end caps to help air flow. Thoughts?
                    The main reason for skipping the cans, besides availability is size. They won't fit. The 1717's BARELY squeeze in.
                    • JMSCARD
                      • Mar 2010
                      • 3444
                      what about the air 1717's? i have one of each... I paid the money and kept the one they accidently sent me... figured for $70 I would find something to use it on.... looks promising for air cooled setup..?
                      • FighterCat57
                        "The" Fighter Cat
                        • Apr 2010
                        • 3480
                        It's got a 6mm shaft and my couplers are 5mm. 6mm-078 Octura's are unobtanium.
                        silly reason, huh?
                        anyone notice the typo in the title of this thread? (legit)
                        • Rumdog
                          • 6453
                          "legit" On the motors fitting.. I know, I tried it with a cooling can on. No go. That sukka's gonna scream!
                          • chummer
                            • 636
                            Not 'till you mentioned it.
                            I'll be following this build. Been wanting one of these myself but too many other projects in the mix right now.
                            "IT IS BETTER TO REMAIN SILENT AND THOUGHT A FOOL THAN TO OPEN YOUR MOUTH AND REMOVE ALL DOUBT"
                            • FighterCat57
                              "The" Fighter Cat
                              • Apr 2010
                              • 3480
                              Some photos; Something tells me I wouldn't be able to use my old laptop case as a carry on any longer...
                              • Jacked1
                                • Jun 2010
                                • 772
                                Jeeeeeze! Two 1717's are gonna be nuts!
                                And if u ever need to sell this boat let me know first! With 2 240's you could put a couple Huge Leopards in there down the road a little bit!
                                It is gonna scream!!!!
                                Fleet: 55" Quad inline T600 Cigarette boat, Twin Mean Machine, Twin T600 47" mystery mono, 4082 Surge Crusher, 1717 8s Genesis, 4074 Villain, "mini mono", 52" Bonzi, Prather Funcruiser, 2 DPI 3.5cc tunnels, 5' Styrofoam recover barge
