Miss Breakaway HPR06
  • tdonnellyem
    • 41
    hey all. my name is Tim and i am starting a catamaran build, an HPR06. It will be a twin drive hull. I am using 2 Lehner 1940/8 hi amp motors, 2 YGE 155 navy ESCs, and hopefully a 4s2p battery set up per motor (going to be a tight fit). batteries are hyperion 4s/35c wtih a 4200Mah. The hull is gorgeous, its the glass/carbon/carbon model. its taken quite some time to get the pieces together but i feel i am getting close. a big thanks to those who helped me when i had questions-espically serge, graill, and sailr! so far i have attached the rudder, the water cooling inlets, and the outdrives. im in the process of letting the flex cables cure to the propeller shafts. i used the loctite 648 method oif attaching them.
    attached are a couple of photos of the hull and where i am at in the build. so far its been a challenge building it but i feel thats half the fun.
    cheers
    tim
  • tdonnellyem
    • 41
    also here is a photo of one of the motors, an esc, and the batteries.
    tim
    • westbeach
      OSE Rocks!
      • 969
      Good choice to go with the HPR's. BTW did you reinforce the transom? What are your plans for steering the rudder? Hanspeter does sell the scale pull/pull hydraulic rams. Looking fwd to see this build progress.
      HPR115 x2 ,Dark Horse Shovel, Delta Force CyberStorm, Delta Force Sniper 23-RTR:
      • blackcat26
        High Speed Junkie
        • Sep 2009
        • 1750
        Welcome Tim! I agree, very nice looking hulls those are!
        • vvviivvv
          • 1148
          i have a 115 too... i only ever ran it twice its collecting dust now i couldnt get it set up properly so ive basically just left it.... gotta get it running@@@@@@ and... 4s2p per motor or 4s2p for the complete boat? i can fit 6s1p in each side no problem...
          missclicked a link and ended up on here then seen this at the top...
          ALSO: i have the same water cooling in method as you, curved pipe, it didn't work for me ... i had bad luck with this boat
          Uk SAW record holder
          • tdonnellyem
            • 41
            westbeach- yes i did reinforce the transom with some 2.5mm thick CF plates. i also purchased all the goodies that hanspeter makes/sells so i have his steering rams. that is actually next to do on the build for me. the one thing i might change/modify is his forward bulkhead. might just go with a CF beam across the top of the tunnel. there is actually a kit that has the bracing done that way. i also have hanspeters motor mounts. i will use them but also want to support the rear of the motor as well. running x442 props- they were balanced/sharped by chuck (egneg). does super nice work
            vvviivvv- sorry to hear about your HPR. gerwin brommer might be able to shed some light on a fix for you. also i am going to try to use 4s2p per motor. a bit of a tight fit. if it doesnt work like you said a 6s battery fits pretty easily on each side of the tunnel
            oh yeah goals of the boat....hoping for 60 mph and around 3-4 minutes of run time. i hope im on target for both. im also going for a "scale look" but using my own sponsors so not quite scale
            • vvviivvv
              • 1148
              I've spoke to gerwin before also spoke to the people that are 'pbspassau'... not good there pretty much the experts
              • Gerwin Brommer
                • Dec 2008
                • 928
                Tim.
                1940/8 on 4s and x442 will not bring you to 60 mls/h.
                You'll need at least 5S to reach that speed.
                • tdonnellyem
                  • 41
                  small update. got the steering rams in and epoxied the servo mount in place. i also have mocked up the motor mounts, just need to expoxy them now. the stuffing tubes are just a basic guide to help align the motor mounts. i still need to anneal them and give them a slight bend. im also going to reinforce the motor mounts with some 1 inchwide strips of carbon fiber cloth. i also want to make a support for the rear of the motor.
