skunkworks cat.
  • BakedMopar
    No Mo Slipah
    • Sep 2009
    • 1679
    I'm with JesseJ. Try a larger diameter prop to drive that hull a little more efficiently. Your temps looks fine. I think mid to high forties once you get it tuned and still be with good temps.
    • sharkbite
      • Aug 2009
      • 324
      yah i have a bunch of props i have a 220 i will try. thank you.
      • Chuck E Cheese
        • 1684
        shark pm me with your e-mail address and i will send the file
        • sharkbite
          • Aug 2009
          • 324
          Hear is a vid from my phone. my 6 year old son took it
          • HYDROJERRY
            • Jan 2010
            • 2503
            sharkbite or anyone else i have the actaul stickers if your looking,,have a hand full....they are about 7 1/2'' long and around2'' wide,,,they are one sided not matching sides...holler
            • driftah
              • 757
              that thing hauls heinee man whoa.I want one I want one...oh but wait I drive in semi rough water dangit
              • sharkbite
                • Aug 2009
                • 324
                Thanks driftah. I have a p 220 to try so it mite go a little faster. Im going to see how it dos in rough water soon I like driving in rough water.
                • Dragonturbo3
                  • Jul 2007
                  • 63
                  Sharkbite - Can I ask you for a link to where you purchased that rudder?
                  • sharkbite
                    • Aug 2009
                    • 324
                    hay Dragonturbo3. the rudder and strut is pro-boat miss geico.
                    • Dragonturbo3
                      • Jul 2007
                      • 63
                      Thanks Sharkbite
                      • sharkbite
                        • Aug 2009
                        • 324
                        Well...... I tryed the 220. It was faster but after 2 fast passes the esc stoped working right. It would stop and start. The esc is still ok but i have to put the 215 back on
                        is it to much amp draw for the esc?
                        • Chuck E Cheese
                          • 1684
                          what batteries are you using? it could be hitting low voltage cutoff. if you are using old or cheap batteries than the sudden drop in voltage could be droping below the 3.0 per cell. try the voltage cutoff "off" or different batteries.
                          • sharkbite
                            • Aug 2009
                            • 324
                            Im using 5000 40c turnigy no that old. but it could be it.
                            • sharkbite
                              • Aug 2009
                              • 324
                              I did not try my thunder power 45c to 90 c burst
                              • Chuck E Cheese
                                • 1684
                                than that shouldnt be the problem. just something to try. i use the 40c turnigy's and regardless of what everyone says, when i put them on the eagle tree there is no significant drop in initial voltage compaired to thunder power 40c's. i am only using it in a ul-1 motor/esc but i am peaking at around 76 amps, 50mm prop pushing 52-53mph. it is running under a pretty high load as the peak rpm is only around 25k.... i know that a 8xl is far less efficient and has a way higher amp draw but i still dont see that as being the problem
