I'm with JesseJ. Try a larger diameter prop to drive that hull a little more efficiently. Your temps looks fine. I think mid to high forties once you get it tuned and still be with good temps.
skunkworks cat.
shark pm me with your e-mail address and i will send the filesee my fleet
: http://forums.offshoreelectrics.com/...hp?albumid=294
sharkbite or anyone else i have the actaul stickers if your looking,,have a hand full....they are about 7 1/2'' long and around2'' wide,,,they are one sided not matching sides...holler
what batteries are you using? it could be hitting low voltage cutoff. if you are using old or cheap batteries than the sudden drop in voltage could be droping below the 3.0 per cell. try the voltage cutoff "off" or different batteries.see my fleet
than that shouldnt be the problem. just something to try. i use the 40c turnigy's and regardless of what everyone says, when i put them on the eagle tree there is no significant drop in initial voltage compaired to thunder power 40c's. i am only using it in a ul-1 motor/esc but i am peaking at around 76 amps, 50mm prop pushing 52-53mph. it is running under a pretty high load as the peak rpm is only around 25k.... i know that a 8xl is far less efficient and has a way higher amp draw but i still dont see that as being the problemsee my fleet
I like driving in rough water.
