problem with my scratch build 36 inch
  • 08gtrking
    • 104
    ok so i have put all the layers of wood but now on the bottom i have noticed that right side lays flat and leftdoesn`t so any help or suggestions appreciated>
  • F1 madness
    • Feb 2010
    • 788
    Alrite bud have you skinned the top of the hull ? any pics
    http://s577.photobucket.com/albums/s...79/F1%20boats/
    Daz from sunny England
    • 08gtrking
      • 104
      no i have not
      • F1 madness
        • Feb 2010
        • 788
        as you skin the top place some bricks on the top once youve lined it up.
        that might help,looks like its slight warped,also you need to sort out the bottom of the rear part of the sponson
        • 08gtrking
          • 104
          you think if i add bondo to the warped side it ll make it even?
          • F1 madness
            • Feb 2010
            • 788
            no wont work,better to try and straighten it the way i said,iv built alot of boats and if i have any warping i cure the way i said
            • 08gtrking
              • 104
              it`s a lot shorter not a little
              • F1 madness
                • Feb 2010
                • 788
                itll work im sure of it,if you bondo it out you may have handling problems
                • 08gtrking
                  • 104
                  what side do i place the brick on
                  • 08gtrking
                    • 104
                    Does it take shape if i leave it over night or ?
                    • F1 madness
                      • Feb 2010
                      • 788
                      Once youve glued the top skins on,place the bricks across ways,1 @ the back and 1 roughly central of the hull and leave over night to cure,that should hold it from then on and you can carry on with the rest of the build
