I decided it was time for me to dabble in the world of outboard tunnel boats. I had a friend pick me up a Woodstuff 30 FE at the Tunnel Championships in Charleston this past spring and I finally got around to starting a P-Spec/Limited build. The Woodstuffs are made by Mike Crawford and this past year he just started to offer FE versions of his tunnel boats. The boat came with the sides of radio box installed and the fore and aft bulkheads lose so you can install them where you want. Unfortunately, I found the radio box too small for my needs. My Turnigy 4S 40C 5000 would barely fit width wise and the top of the box was only 1/8" above my battery. Because of this, there was not enough room for a speed controller to fit on top of the battery pack. So with tears in my eye's, I ripped the sides of the battery/radio box out of my $300 hull and fabricated a new one. Once the new box was installed, I had to come up with a steering system that would give me maximum room on the inside of the box and yet leave allot of adjustment flexibility for the OS lower. I came up with a pull/pull cable system that exits through the top of the box via some brass tubing with a "S" bend. I think it came out nice. I left the cable sleeve long on the inside of the box to prevent cable chafing with the battery. I also installed a 1/2" motor mount standoff which Dick Loeb recommended to improve handling with the OS lower. I sharpened the skeg of the the OS lower and drilled out the water pickup for increased cooling. I'm awaiting a FE coversion kit for the OS from Hyperformance Products. The boat is all sealed up and I just sprayed the cowling with some Krylon Fusion Burgandy. With any luck I'll get her in the water in a week or two. Again this is my first tunnel so feel free to add any comments or suggestions.
Seriously, I just glued six pieces of wood together and drilled some holes. The the real art on that boat is the bottom.
