is two wires stay connected to the motor it will still stutter and most likely draw power and isn't good for the ESC, you could attach it to all three wires to be switchable.
ONBOARD Hydro RETRIEVAL sytem!!
Thanks guys. This is the info I was looking for. Sounds as if it will overcomplicate things. I guess I'll be sticking with the simple relay switch that taps power from the balance jack.Originally posted by Jacked1 View PostAnd to switch from one motor to the other without changing the esc you could use some fets and a full on gate signal to the leg of the motor you wanted to use and you would need to do this to at least two legs of the motor. But then again You would also need a floating gate controller since the source voltage would not be grounded.
Never seen this one before. Just read the whole thing. Thanks for dredging it up Revoltrunner.
Excellent stuff Pete. Love it.See the danger. THEN DO IT ANYWAY!!!
LOL. Thanks guys. Hard to believe that it has been over (4)yrs!!! It really became practical once I found that little electronic unit that sensed 'reverse' on the throttle. My neighbors thought I was nuts. I was running it upside down more than right side up!!!!
