Here is the video of the final design!: http://www.youtube.com/watch?v=At7jWr7iYC4
OK, so we all have been aggrevated with an upside down hydro!!
I started working on an onboard retrieval system that packages into the Vacupickle cowl. It runs an alternate prop if upside down (reef racer prop, brushed motor, 5v). I'm sure the haters will speak out! ....but I really think it will be great during practice and liesure runs, etc!! I rigged one of my gassers with this system (see second photo) and it works great. A reverse command on the TX engages the lever switch and off she goes!
The electric Pickle will require some sort of logic though since there is no throttle servo. Most likely a PWM switch. Not sure what I'm going to do here yet.
Regarding asthetics, it will look rather stupid to have a prop on the back of the turbine, but I think it can be hidden by a small, vented shroud around the turbine.
Should be fun to really put the steam behind this boat and not have to worry about blowovers.
I flipped it!!! Just run the alternate power and she's back home in a flash.
