Guess what I bought?
  • TRXRUSTLER
    • Jul 2009
    • 88
    I got this from my good friend who ownes my LHS for $50 buck, came with a turn fin, rudder, linkage with boot. It is perfect.
  • G-UNIT
    • 971
    Some people have all the breaks.
    • forescott
      Hopelessly Addicted to RC
      • 3009
      Let the build begin!
      • TRXRUSTLER
        • Jul 2009
        • 88
        I gonna put my Miss Bud built on hault and run the turnigy 120a marine and the Feigao 8XL on 4s in this hull and see what happens. I still haven't received my esc yet, I call the post office and they said it was held up in customs in NY. So let the wait begin. Does anyone know what size collet I need for this, I have the proboat flexshaft but Im not sure which collet will fit. I need a 5mm to whatever the Proboat shaft size is?
        Thanks, Chris
        • forescott
          • 3009
          I run the same setup, except the 9xl, and its fast and runs cool! You're setup should really make it fly!
          • TRXRUSTLER
            • Jul 2009
            • 88
            I was thinking about using a UL-1 motor with the turnigy 120a in this, because I want to run a 4s in the nose of it to help keep it in the water and I don't have enough space to fit an XL in front of it. I'll post a pic.
            Chris
            • forescott
              • 3009
              Good idea. Thats one bad thing about the xl motor in this hull. I found that out the hard way! The ul-1 motor is a good choice.
              • TRXRUSTLER
                • Jul 2009
                • 88
                Now what size prop do you think I should use, because the UL-1 uses 3/16 props so I can't get the stock one?
                Thanks, Chris
                • dana
                  • Mar 2010
                  • 3660
                  You just need a 1/8 to 3/16 sleeve to use other props. Steve sells em here on ose. Or you can buy the proboat prop and it comes with the sleeve
                  • osprey21
                    • 723
                    Nice score for $50!
                    I like the hope chest too.
                    • forescott
                      • 3009
                      I use the prop adapter, which is actually 2-pieces of brass tubing to take up the slop.(3/16 & 5/32) I'm getting in the mid-40's on an octura 442 with no heat issues whatsoever.
                      • johnnyoverkill
                        • 295
                        Prop shaft
                        Chris,
                        Great buy!
                        Depending on when the hull was built, you have either the 3 or 4mm staight shaft. I'd bet on the 3mm. Check with Jeff Wohlt, he can cut the adapter for you.
                        Have fun with the build,
                        John
                        "When too much is just right!"
                        • TRXRUSTLER
                          • Jul 2009
                          • 88
                          Thanks guys, I will be buying some things when I get my pay check. I will keep you updated. Also would the UL-1 motor be powerful enough for this hull on 4s?
                          Thanks, Chris
                          • forescott
                            • 3009
                            Originally posted by johnnyoverkill View Post
                            Chris,
                            Great buy!
                            John
                            It has an 1/8 inch prop shaft.
                            • HYDROJERRY
                              • Jan 2010
                              • 2709
                              I have a one with the stock motor and esc running two 2s 5000 lipos and 442 prop and last time she ran 41mph...fast enough for me..
