PVSea Monster!
  • FighterCat57
    "The" Fighter Cat
    • Apr 2010
    • 3784
    PVSea Monster!
    Just messing around with some PVC and came up with this. Think I might actually have enough spare parts to make it run.... If I can figure out a way to steer it.
  • osprey21
    • May 2010
    • 723
    Graupner thrusters?
    • FighterCat57
      "The" Fighter Cat
      • Apr 2010
      • 3784
      Originally posted by osprey21 View Post
      Graupner thrusters?
      Link?
      • j.m.
        • Jul 2008
        • 847
        I say twin rudders off the back of each sponson.
        My question is whether or not it will float... You might want to also smooth out the bumps from each tube intersection.
        Jon
        • FighterCat57
          "The" Fighter Cat
          • Apr 2010
          • 3784
          Jon
          Oh, yeah, it'll float. The sponsons are going to be set inside pool noodles.
          • j.m.
            • Jul 2008
            • 847
            OOOOOOOOOOOohhhhhhh!!!
            Now it makes sense.
            That'll work good then!!
            • johnf
              • Dec 2009
              • 1086
              hah, I'll be interested to see this come together if you finish it.
              Catching Air!
              • BakedMopar
                No Mo Slipah
                • Sep 2009
                • 1743
                Being that I have one and went through four different setups. You will be the happiest with a steerable outdrive system like the pro-boat ones or an outboard. Directional thrust is the way to go.
                • FighterCat57
                  "The" Fighter Cat
                  • Apr 2010
                  • 3784
                  he he... if.
                  Yeah, since it's a rescue, that would help greatly! I don't know much about the outboards though or even which one would be the simplest.
                  • FighterCat57
                    "The" Fighter Cat
                    • Apr 2010
                    • 3784
                    OK, still don't know how I'm going to steer it, but I did get a 1/5th scale waterproof servo to help with the task.
                    I'm starting to think a pair of EDF fans and a V-Tail will do the trick. Still wating to see if I want to do the boogie board as and EDF or prop. The spare parts are growing, so the options are too!
                    My concern with EDF is flipping it. Although, it would probably still move upside down.
                    • Brushless01
                      • Apr 2010
                      • 489
                      Great rescue rig !!
                      Prince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.
                      • FighterCat57
                        "The" Fighter Cat
                        • Apr 2010
                        • 3784
                        Originally posted by Brushless01 View Post
                        Great rescue rig !!
                        Thanks! Now I just have to figure out how to turn it!
                        • ozoneone
                          • Mar 2010
                          • 31
                          Air rudder! My BBRB spins like a top at full rudder.
                          http://forums.offshoreelectrics.com/...5&postcount=14
                          and I used a hacksaw blade to cut the board, BTW
                          • Brushless01
                            • Apr 2010
                            • 489
                            A setup like the Aquacraft Alligator tours would be sweet
                            • FighterCat57
                              "The" Fighter Cat
                              • Apr 2010
                              • 3784
                              Thanks! That's exactly what I was thinking about building. =)
