PVSea Monster!
  • FE Wannabe
    • Jul 2007
    • 654
    #46
    Originally posted by rearwheelin View Post
    Wish I could have used this yesterday when my 23 lb boat was nose up in the water with no hatch. What if there was a hook dangling were you would be able to grab ahold of something to drag it in. For now i dump my ice box and use it to float while dragging the boat. Thanks for the idea
    That is one of the reasons I designed my PVC rescue boat with a lift, controlled by my radio's third channel. It allows nose up rescues! The lift lowers a platform as much as 17 inches below the waterline, so I can get under a stalled/flipped/flooded boat and lift it to dry air and drive it back to shore.
    I have lifted a 10lb can of nuts and bolts with the 1/4 scale continuous rotation servo that I use as a winch, so I feel confident that I could lift pretty much any partially submerged FE boat enough to bring it back to shore.
    • rearwheelin
      • 2101
      #47
      Originally posted by FighterCat57 View Post
      As in sit in it? And paddle?
      As in hold the handle of my medium size ice chest with one hand and swim with it to the boat then one hand on boat and other on ice chest so I don't drown. A life vest can do the same thing I need a fetcher cause it is going to start getting cold
      --Albert Einstein
      • FighterCat57
        "The" Fighter Cat
        • Apr 2010
        • 3784
        #48
        That's hilarious!
        Yeah, time to get a rescue vessel.
        • RCKong
          • Sep 2009
          • 1680
          #49
          LOL...
          • FighterCat57
            "The" Fighter Cat
            • Apr 2010
            • 3784
            #50
            HA! EEEEEETS ALIIIIIIIIIIIIIIVEAHHH!
            OK, so next is to step the runners by overlapping the pool noodles and get rid of the curve at the runner transom. Then add the center net to catch the vessels. Not quite sure what kind of net, maybe fishing string, but just enough to snag and push the distressed craft.
            • eboat
              • 726
              #51
              Does it back up ??
              • FighterCat57
                "The" Fighter Cat
                • Apr 2010
                • 3784
                #52
                Originally posted by eboat View Post
                Does it back up ??
                Not yet. Have to hook up the reversing ESC's.
                • BakedMopar
                  No Mo Slipah
                  • Sep 2009
                  • 1743
                  #53
                  What I have done was put some "T" fittings on the forward cross bar and put a piece of pvc that hangs down in the water to use as push bars on mines. You may want to put a boat and make sure it pushes it with load.
                  • Diegoboy
                    • Mar 2007
                    • 7444
                    #54
                    I simply love all these variations on my contraption. It's giving me some ideas on the Contraption Mk2. Already in phase one is a collapsable frame for easy transport.
                    • RCKong
                      • Sep 2009
                      • 1680
                      #55
                      FC that's coool... ping pong ball net works good for net. I used cargo net on one of mine. I've built 3 or 4 of these things trying to find what works the best. Ski's on the front makes it ride up on top of the boat your trying to retrieve, found that out trial & error. I had to put small chunks or re-bar in the front PVC to keep the nose down, that helped alot. I'd be interested in seeing a twin fan hydro or rigger, it would haul the mail.
                      • FighterCat57
                        "The" Fighter Cat
                        • Apr 2010
                        • 3784
                        #56
                        Hmmm. I'm thinking a fishing line with weights and a continuous loop servo to wind them up and lift the vessel out of the water.
                        Basically get close, drop lines then once over the vessel, pull the lines taught and raise the vessel up almost out of the water.
                        Can someone point me to a continuous loop servo or how to make one?
                        The other approach is a series of bobbers and weights and do circles and then pull the line in taught.
                        • BakedMopar
                          No Mo Slipah
                          • Sep 2009
                          • 1743
                          #57
                          FC look for a retract servo. You can also modify any regular servo. You just need to cut the stop out of the case. If you open up the case where the main output is it's usually keyed. Cut the stub off and viola. I've done it before for making winches on crawler rigs and it works fine.
                          • FighterCat57
                            "The" Fighter Cat
                            • Apr 2010
                            • 3784
                            #58
                            That sounds perfect. Then I'll just route some fishing line and tie in some weights.
                            In theory, it will sink the line, then lift the vessel.
                            Might be too many maneuvers to do from afar though.
                            • BakedMopar
                              No Mo Slipah
                              • Sep 2009
                              • 1743
                              #59
                              Yes that's the hardest thing about these vehicles. Especially when theyre way out and you have current and winds.......
                              • H2OCamel
                                FAST ELECTRIC EVERYTHING
                                • 494
                                #60
                                Cool ideas! I need to make one!
                                "Discussion is an exchange of knowledge; an argument, an exchange of ignorance." Robert Quillen
