Miss Bud Gen 1 Conversion
  • TRXRUSTLER
    • Jul 2009
    • 88
    I have a Proboat Miss bud straight shaft that I am converting to electric and flex drive. I was wondering how you guys got rid of the engine mount that are from the old nitro engine? I am going to be using parts from the Miss Elam to convert it to flex drive. I will be running a Turnigy 120a, Feigao 8XL on 4s with a x440 prop. If you guys could help me out with this I would appreciate it.
    Thanks, Chris
    (This is not my boat, its just to explain what I mean)
  • JimClark
    • 5913
    yank it out
    Billy Graham
    • TRXRUSTLER
      • Jul 2009
      • 88
      With what? I don't want to break the hull, its pretty thin walled.
      Chris
      • JimClark
        • 5913
        You don't need it in there electric motor mounts are totally different
        Billy Graham
        • electric
          • 1973
          If it is epoxied in there. Break out the hair dryer and heat it up then pull it loose. Someone else told me about this and I really had my doubts, but I tried it and darn if does not work! It seems that at a certain temp the glue fails and lets loose. I just used a hair dryer(as suggested) and without a lot of time it worked.
          • TRXRUSTLER
            • Jul 2009
            • 88
            I have a mount that I bought on here (OSE) and I need to remove the old one out of there to install the new one.
            Thanks for the hair dryer tip will try it when i get home.
            • blackcat26
              High Speed Junkie
              • Sep 2009
              • 1750
              You gonna cut out the radio box also? Think it's gonna be in the way. If you are carbon fiber the floor from the fron to the transom, those hulls are flimsy compared to the elam/formula.
              • forescott
                Hopelessly Addicted to RC
                • 3009
                I'll be watching your thread colesly! I'm doing the same conversion with the same motor/esc. in an old miss llumar!
                • TRXRUSTLER
                  • Jul 2009
                  • 88
                  The radio box and nitro engine mounts are gone. I have the servo and rudder installed, I am waiting on the flex shaft and stuffing tube. It should be here on thursday. I am going to take some pics tomorrow. Where do you get the carbon fiber mate?
                  Thanks, Chris
                  • domwilson
                    • 4412
                    You can leave them in and use this type of mount..
                    http://www.offshoreelectrics.com/pro...?prod=cen-bj16
                    Government Moto:
                    • TRXRUSTLER
                      • Jul 2009
                      • 88
                      Its too late for that, its already ripped out. I bought this one http://www.offshoreelectrics.com/pro...prod=ose-80080
                      Chris
                      • TRXRUSTLER
                        • Jul 2009
                        • 88
                        Heres some pics so far.
                        • blackcat26
                          High Speed Junkie
                          • Sep 2009
                          • 1750
                          Is your servo rod going over the original hole? Gonna be hard to seal that off. I'd shoot it thru the original hole thats there and slap a good ole rubber boot on her. Also if its not too late try and set the servo where it's pulling the wire for right hand turns and not pushing it.
                          • TRXRUSTLER
                            • Jul 2009
                            • 88
                            I will move the rudder to the left side of the boat so I could use the original hole and make the servo pull when it turns right. Thanks for the info.
                            UPDATE: Heres some pics, I just switched everything over.
                            Chris
                            • blackcat26
                              High Speed Junkie
                              • Sep 2009
                              • 1750
                              That will work much better!
