Project Genesis!
  • FighterCat57
    "The" Fighter Cat
    • Apr 2010
    • 3784
    #106
    Originally posted by Rumdog View Post
    Make sure you run at least a .187 flex cable! For props, I wouldn't start any smaller than 45mm. That will probably end up being too small as well. You'll want enough prop to load the motor so it can make power.
    Current Config; Hydra 240lv, 1527 1.5d, 6s2p (4 x 3s1p 30c Series/Parallel) and a 445 prop on an 078 wire drive.
    My big concern is being top heavy and narrow.
    ________
    YAMAHA MUSIC FOUNDATION HISTORY
    • Rumdog
      • 6667
      #107
      I dont think it being more top heavy will matter too much. You wont know till you run it though. I think the 4 lipo packs in the sponsons will make up for any difference in motor weight. Do you have a motor mount?
      • FighterCat57
        "The" Fighter Cat
        • Apr 2010
        • 3784
        #108
        I have this one on the way. I don't know the bolt pattern on the 1527 though.
        ________
        FORD EIFEL
        • tiqueman
          • Jul 2009
          • 5866
          #109
          Originally posted by Alfa Spirit View Post
          Twin setup , 5S per 540XL/9 motor and 2 Turnigy 120A esc should be ok?
          Youll be fine w/ that setup.
          • Alfa Spirit
            • 2183
            #110
            Yes Tiqueman I think so. my only technical problem is to find a pair of stingers more than 10cm long.
            If you' ve got a link let me know
            This model 3/16" from HOTR is 7,8cm long, what do you think using a 3cm aluminium brace (spacer) ?
            • Make-a-Wake
              FE Rules!
              • 6057
              #111
              The new mounting holes are just a hair farther apart then a standard 540 motor. There may be enough wiggle room to get the screws between the spacing on that mount............who knows, it may be made for it and just fit right on.
              Here is a suggestion only............. If it were my $250 motor i would want it kept as cool as possible, and I myself would use two 1509 jackets as the long one for the 1527 wont work with that mount. you have 50mm or so between the mount and the support which will accept the 38mm jacket nicely.....then you will have about 40mm hanging out the back which should also accept one. This is of course based on the jacket fitting diameter wise which i believe it will............double check with Steven.
              • tiqueman
                • Jul 2009
                • 5866
                #112
                The mounting surface area is too large on those. They will not work.
                • Alfa Spirit
                  • 2183
                  #113
                  If I don' t find long stingers I can build something like this. Motor ==> flex collet ==> flex shaft ==> flex collet ==> shaft with sterntube
                  What do you think?
                  • tiqueman
                    • Jul 2009
                    • 5866
                    #114
                    Ive heard a few builds like that. Does that allow the stinger to be adjusted somehow?
                    • Alfa Spirit
                      • 2183
                      #115
                      No adjustment but is it really necessary? I don' t think. shaft with sterntube is parallel to the bottom of the hull
                      • FighterCat57
                        "The" Fighter Cat
                        • Apr 2010
                        • 3784
                        #116
                        Hmmm. Didn't think about the cooling can. Haven't really thought it through, waiting to have motor in hand. This mount is for my 2200 in another boat, but was thinking it might work, but guess not.
                        OK, so time to source a motor mount that will work with the bigarse cooling can that's coming with it.
                        ________
                        Herbalaire review
                        • FighterCat57
                          "The" Fighter Cat
                          • Apr 2010
                          • 3784
                          #117
                          Nope. I'm officially looking for one.
                          ________
                          Toyota ipsum history
                          • tiqueman
                            • Jul 2009
                            • 5866
                            #118
                            Contact Pete. Hes got a thread on the forums of mounts he builds. Bonewar just used one in his cat. Very incredibly nice
                            http://forums.offshoreelectrics.com/...ad.php?t=10698
                            • FighterCat57
                              "The" Fighter Cat
                              • Apr 2010
                              • 3784
                              #119
                              Done. Cool stuff.
                              ________
                              Vapir One
                              • FighterCat57
                                "The" Fighter Cat
                                • Apr 2010
                                • 3784
                                #120
                                Turns out the orange & CF mount works perfectly. Will need to make a stringer support, but it wraps around the motor perfectly.
                                Motor's here. Mounts here... Hydra's here... Gonna be a fun day tomorrow. =)
                                ________
                                BUY SILVER SURFER VAPORIZER
