Originally posted by Bill-SOCAL
View Post
Darin's Top Speed 2 FE Conversion...
How DARE you get an orange one!!!!! I have the exclusive rights to that color!! I'll have to contact Tower to issue you a refund and send you a nice white one!!!
Leave a comment:
graphics
Here's how she looks with some simple graphics. Needed something bold to see her better on the course
Leave a comment:
I just can't stop smilin' !!!Originally posted by Darin Jordan View Post..
By the way... Tony... I TOLD YOU SO!! FUN, EH!???
Leave a comment:
That's exactly what I did... Actually... I've shorted the shafts on every motor I own... They are usually at least 3/16" or so too long... ON the SV27 motor, I trim it about to the flat... maybe a tad further... Keeping that steering block sealed really helps with maintaining the lubrication on the shaft...Originally posted by properchopper View PostTo avoid spacing the motor up & raising the CG I shortened the motor shaft a little on the ole' bench grinder
Leave a comment:
You're welcome! That's awesome....Originally posted by properchopper View PostServo was weak, will free up the linkages/volt it up/ or replace with higher torque unit. THANKS, Bro !
Servo... Do youself a favour (all of you) and spend the money on at LEAST a 90 in/lb torque servo... Hitec HS645-MG or equivalent is what the Nitro guys use... A LOT of handling issues can be solved by simply doing this...
Leave a comment:
Just freed up the servo linkages some & it seems much better !Originally posted by properchopper View PostServo was weak, will free up the linkages/volt it up/ or replace with higher torque unit.
Leave a comment:
re :
Thanks !! You'll love this boat; plus it has that "scale look " that we both like. BTW, I noticed that you spaced your motor up so the coupler wouldn't hit the outdrive [ I assume that's why you did it]. I had the same problem : the coupler was right against the motor, bottomed on the shaft & was right up against the top of the drive.. To avoid spacing the motor up & raising the CG I shortened the motor shaft a little on the ole' bench grinder [shielded the bearing to keep grit away from it] , allowing it to be higher on the shaft. Your motor is taller, you might give this a try to keep the CG down some. I know Darin's the man with the plan here, but if I can help in any way let me know.
Leave a comment:
Awesome man. Mine is 90% done. I am out of time to build untill the 5th now so it will be the 9th before I can get it in the water.
Leave a comment:
Thank You Darin !!!!!!!!
All I can say is WOW !!! Ran perfectly trimmed out at 9.5 " CG. Flew on calm water & handled race/chop like a champ [ the gassers were practicing for a race]. Cornered like a dream & left the Supervees floating upside down
Went from 442 to a P215 to a 642. Loved the 642 & temps were so low I didn't bother with the temp guage ! Servo was weak, will free up the linkages/volt it up/ or replace with higher torque unit. THANKS, Bro !
Leave a comment:
I'm not worried about the BOAT getting wet ; It's my damn hairdo ! lol [check out before and after boating in the rain !Originally posted by Darin Jordan View Post
Rain??? Dude... it's a BOAT!!
Leave a comment:
Looks like you are ready to go, Tony! Nice work! Get a GPS in there and let's hear how the testing went...Originally posted by properchopper View PostModded [ thanks Darin
] recovery pads installed. Boat ready for water. May have to test in the rain
Of course, I live in Washington... I'd have to say that to stay SANE!!
Leave a comment:
re:
Attached FilesLast edited by properchopper; 01-27-2008, 11:43 AM.
Leave a comment:
I found the recovery pads made a big difference also. I would say use them.
Leave a comment:
Thanks, Darin. I have them trued & painted & ready to install, just wanted to check before attatching. :)
Leave a comment:
Leave a comment:
