Awesome man. Mine is 90% done. I am out of time to build untill the 5th now so it will be the 9th before I can get it in the water.
Darin's Top Speed 2 FE Conversion...
re :
Thanks !! You'll love this boat; plus it has that "scale look " that we both like. BTW, I noticed that you spaced your motor up so the coupler wouldn't hit the outdrive [ I assume that's why you did it]. I had the same problem : the coupler was right against the motor, bottomed on the shaft & was right up against the top of the drive.. To avoid spacing the motor up & raising the CG I shortened the motor shaft a little on the ole' bench grinder [shielded the bearing to keep grit away from it] , allowing it to be higher on the shaft. Your motor is taller, you might give this a try to keep the CG down some. I know Darin's the man with the plan here, but if I can help in any way let me know.2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
Just freed up the servo linkages some & it seems much better !Originally posted by properchopper View PostServo was weak, will free up the linkages/volt it up/ or replace with higher torque unit.
You're welcome! That's awesome....Originally posted by properchopper View PostServo was weak, will free up the linkages/volt it up/ or replace with higher torque unit. THANKS, Bro !
Servo... Do youself a favour (all of you) and spend the money on at LEAST a 90 in/lb torque servo... Hitec HS645-MG or equivalent is what the Nitro guys use... A LOT of handling issues can be solved by simply doing this...
By the way... Tony... I TOLD YOU SO!! FUN, EH!???
Darin E. Jordan - Renton, WA
That's exactly what I did... Actually... I've shorted the shafts on every motor I own... They are usually at least 3/16" or so too long... ON the SV27 motor, I trim it about to the flat... maybe a tad further... Keeping that steering block sealed really helps with maintaining the lubrication on the shaft...Originally posted by properchopper View PostTo avoid spacing the motor up & raising the CG I shortened the motor shaft a little on the ole' bench grinderDarin E. Jordan - Renton, WA
I just can't stop smilin' !!!Originally posted by Darin Jordan View Post..
graphics
Here's how she looks with some simple graphics. Needed something bold to see her better on the course
Attached Files2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
How DARE you get an orange one!!!!! I have the exclusive rights to that color!! I'll have to contact Tower to issue you a refund and send you a nice white one!!!Don't get me started
re :
My boat is red. White was my first choice but no longer available.Originally posted by Bill-SOCAL View PostHow DARE you get an orange one!!!!! I have the exclusive rights to that color!! I'll have to contact Tower to issue you a refund and send you a nice white one!!!2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
Prop Question
Darin, which prop are you using? Since this is the SV27 set up I was going to use either a 42/55 or 440/3. I noticed most of the people are using 642's. Do I need to go prop shopping? Tell me soon so I can get one polished and balanced before our first race.
member P.S.F.E.M.B.C.
Sunny skies and smooooooth water...............
Carol, you'll probably want a 642 in your prop box anyway.
I currently have my 642 mounted on the tunnel, as my 2 42x55's are on the LSH (SV27 power) and my SV27Spec boat, since those 2 classes have a spec'ed prop.
As far as I know, we haven't spec'ed a prop for Tunnel, and even though this gives certain club members an advantage, I prefer we keep it open.
Sounds like the X642 is a great starting point to me.
This class is gonna be alot of fun!
A 642 would be a good place to start... Might actually be too much pitch... I haven't used one so I'm not sure...Originally posted by CarolHazlett View PostDarin, which prop are you using? Since this is the SV27 set up I was going to use either a 42/55 or 440/3. I noticed most of the people are using 642's. Do I need to go prop shopping? Tell me soon so I can get one polished and balanced before our first race.
I used a 440/3 with good results...
Each prop seems to have plusses and minusses on these tunnels... getting a good balance between speed and handling is going to require some setup time... I don't really know which one is "best"... I'm still playing with it...
The SV27 motor is a fairly low RPM setup with gobs of torque... It seems to like diameter and blade-area... How you combine those I'll leave up to you for now... Some things are best discovered through trial and error, and I can't give up ALL the secrets just yet!
I've already told Corey too much, and now he's whooping my butt every chance he gets!
Motor Mount
Darin, I noticed on your motor mount that you did not use a spacer plate. Did you cut your shaft instead? If you did, did that leave very much of a flat for the collet set screw? I am using the same REK mount from Ray Fuller that you are.
Originally posted by CarolHazlett View PostDarin, I noticed on your motor mount that you did not use a spacer plate. Did you cut your shaft instead? If you did, did that leave very much of a flat for the collet set screw? I am using the same REK mount from Ray Fuller that you are.
Carol,
Yes... I trimmed the motor shaft length down just to the beginning of the flat... I then extended the flat a tad up the shaft...
Another method that I've seen used and looks very clean is to use The spacer shown in the attached picture and is made by Integy for a Clod Buster. I saw this done on another site (thanks Jim!) and it makes some sense... though I prefer to keep the weight as LOW as possible...
Hope this helps...Darin E. Jordan - Renton, WA
re :
Carol, I ran into the same situation. I taped up the motor to keep grit out of the bearing & ground the shaft shorter with the 'ole bench grinder. Did re-file the flat a little longer as well. I'm with Darin on keeping the CG as low as possible. I didn't feel too bad doing this on the SV27 motor, but grinding on a Neu may feel a little sacriligeous !2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
