Darin's Top Speed 2 FE Conversion...
  • pmisuinas
    • Mar 2008
    • 173
    #136
    Well, I have a really basic question since I can't seem to find it searching on my own...
    Where did you guys get your outboards? The only thing I can find is the Aquacraft EP-1 and Graupner--is this what you are using with different motors? TIA...Pete M
    • FinzUp
      • Mar 2008
      • 11
      #137
      Out Board
      try this link as it is a REK unit for 89.99 fuller Hardware
      The rest is up to you Also follow all the Build links
      Good luck.
      Tropical Bill
      • pmisuinas
        • Mar 2008
        • 173
        #138
        Thanks, much appreciated...Pete M
        • calcagno45
          • Mar 2008
          • 1050
          #139
          Darin, in this picture, can you tell me what sizes of tubing did you use? Thanks
          • Darin Jordan
            • 9446
            #140
            I don't really remember... I think the water lines are 5/32"... The three for the ESC wires are "big enough to fit the contacts w/ shrink through", and kind of the same deal on the steering... They were all just bits and pieces from my brass tubing box...
            Darin E. Jordan - Renton, WA
            • calcagno45
              • Mar 2008
              • 1050
              #141
              ok thanks!! Im trying to win one on ebay, and if so Ill be following pretty much the setup
              • TRUNKMUNKY
                • 61
                #142
                Did you get it? They are alot of fun to run,and fun to build.!!http://www.youtube.com/watch?v=sUteIPgYuAE Crappy video of mine.
                • calcagno45
                  • Mar 2008
                  • 1050
                  #143
                  Nah, I got outbid.
                  • smm_cbf
                    • Mar 2008
                    • 279
                    #144
                    is there a link for the adjustable mount? can't find it...
                    • Stinger9D9
                      • 378
                      #145
                      I finally finished the orange TS2 I bought off the swap shop forum a couple of months back. (It was a bit of a challenge considering the state I received it in, but that's a different story for a different thread).
                      First off, here's the setup:
                      SV27 motor on a REK lower tilted up a bit to (try) and lift the nose, 70A ETTI ESC, Octura X440 2 blade and...12 IB 3600's
                      What a dismal failure.
                      It's WAY too heavy with nimh cells. The prop cavitated like crazy. The nose actually plowed down into the water at least once, and the water pickup was basically non functional because of the cavitation. I tried to lower the outboard a bit, then tried a graupner 40mm CF prop, neither made much difference.
                      So basically, it was slow (like 10-12mph), WAY too hot and tried to end it all by heading for Davy Jone's locker a couple of times. Let's just say, I ended that trip to the pond shortly after it started.
                      Ok, I know now that this setup is not even worth considering nimh's, Lipo's are a must.
                      My question is about prop selection, outboard depth and angle, what prop would be better? I think my overly aggressive upward angle contributed to the cavitation too, do you agree?
                      • TRUNKMUNKY
                        • 61
                        #146
                        Maybe I can help.,you must have the lower unit set at the proper height,this will mean using the ts2 manual.Just use the biggest side of the stand it came with to set your boat on,then you can set the motor and lower unit height,..just make sure you use the wide side of the boat stand.
                        • Stinger9D9
                          • 378
                          #147
                          Yeah, I think the motor was too low in the water, the prop was in too deep, and could not wind out. It started to get going, but looked like the motor just could not get the rpm needed to push the boat up on plane properly.
                          Has anyone had any success at all running one of these on nimh's? Or will I have to put it back on the shelf until the budget allows for a pair of those?
                          • smm_cbf
                            • Mar 2008
                            • 279
                            #148
                            im sure it can get on to plan with cells. you might just have to find the right balance point, i might do a bby tunnel on 12 cells, but thats built for cells, so....
                            • Stinger9D9
                              • 378
                              #149
                              Ok, I raised the motor up to get the bottom of the prop shaft 1/8" above the bottom of the sponsons, and also trimmed it to exactly neutral.
                              It's better, notceably faster (still pretty slow though), but it still runs REALLY wet. I still don't think the motor is hitting full rpm.
                              I think I read somewhere that the SV motor likes to be a bit higher out of the water than the recommended 1/8" above the sponsons. I'll need to slot out the dubro mount a bit to get the lower unit higher up.
                              The motor ran really hot again. I think a better water jacket is in order as well.
                              • smm_cbf
                                • Mar 2008
                                • 279
                                #150
                                anybody know where to get the mount? looks perfect for my next build
