hpr ct04 67 inch cat build
  • scullyeng
    • 54
    #76
    Octura x447/3
    • Rumdog
      • 6667
      #77
      x447??? Way more! X455's.
      • blackcat26
        High Speed Junkie
        • Sep 2009
        • 1750
        #78
        Rummy did u mean 455? 447's are way too small
        • Rumdog
          • 6667
          #79
          haha. yeah... I'll fix that post oops
          • blackcat26
            High Speed Junkie
            • Sep 2009
            • 1750
            #80
            LOL They make 457's in reverse. Never had a boat that big but know 447's are too small.
            • blackcat26
              High Speed Junkie
              • Sep 2009
              • 1750
              #81
              Ok Avery I did a little research and found a boat Mudl build on You Tube called Xtreme Xhibit. He is running his twin on Lehner 3060/7 which are 1121kv on 10s. That makes his unloaded RPM about 41k. Those produce about 7kw or 7000w. He is running a x457 c/r. You could still have a boat that hauls ass with the Leopard 5692 motors. Leopard motors are lighter also.
              Two choices to really fly.....1340kv on 8s, or 1090kv on 10s
              Or a more mild setup of 730kv on 12s. These motors produce about 5500w and should really motivate that hull. Hope this helps.
              • ManuelW
                • Oct 2010
                • 786
                #82
                The question is how many lipo cells you want to run.
                Concerning mudl: This was the setup of season 09' and he had quite a lot of troubles with it. For further information contact him. This year he ran 3060/8 on 12S with 40.160 ESC's and it was brilliant, just take a look: http://www.youtube.com/watch?v=zA3qpd4SjIk
                Anyway, 750kv on 12S, 1340kv on 8s or 1090kv on 10S, the Octura X457 wouldn't be a bad choice to my mind. But be aware that this will drive quite fast too.
                best regards,
                manuel
                • avery
                  • 96
                  #83
                  Sounds good tks all the build will be slow due to funds but only few more months I'll be there think I'll do the milder 12s as don't want to burn nothing
                  • avery
                    • 96
                    #84
                    well wanted to whish all merry christmass and happy new year hope all r well
                    • TotalPackage
                      • 622
                      #85
                      Same to ya hey avery what motors you gonna run? I hope you threw out the twin screamer idea for some inrunners. Hey pm me so i can get that brushed stuff of your hands. That will get you some cash
                      • avery
                        • 96
                        #86
                        hi total it ok i bought the lepoard 5692 750 kv motors so now saving up for two swordfish 240 hv and props and such
                        • TotalPackage
                          • 622
                          #87
                          oh yess sounds good. 10s 2p? thats gonna be a good cheaper build well cheap when compared to two neus.Im late in this discussion what props u gonna run?Thats gonna be nice avery. Dont forget to pm me about those panasonic ill take them off your hands.Id really like to get them.
                          • TotalPackage
                            • 622
                            #88
                            far as props id still recoment starting small coz sometimes the smallers run better i mean chuff has got a 19 pound scale doing wheelies with a 3bladed 646 so common sense tells you two would certainy move that boat. No disprovin anyone but id start in that area and work up if you look at manuels he has 457 CUT DOWN to a much smaller diameter.Lengh of a hull means alot but weight and actual running surface on step matters too.
                            • TotalPackage
                              • 622
                              #89
                              I do want those panasonics tho if you willing to sell i also wanted to remind you o this this might help you make some prop consideration you can certainly pueh that boat with 447 might not be ideal but you could migh be ideal but id be looking at a 6 series in that diameter just an example 50 plus inch boat with 442's so you can almost know that a pair of 40 plus mm props will work
                              Proof:http://www.youtube.com/watch?v=0SdG4Kis9NA advice is great real world test are better.
                              Its a small issue Im just really glad to see you get your powerplants. I love those hulls.
                              • blackcat26
                                High Speed Junkie
                                • Sep 2009
                                • 1750
                                #90
                                42mm props on a 67" boat? That's about as good advice as those Panasonic brushed 12v motors you advised him to get.
