Project Apparition!
  • FighterCat57
    "The" Fighter Cat
    • Apr 2010
    • 3784
    #76
    OK... waiting on parts now. Ouch my wallet hurts. Will update more later.
    Got to learn quite a bit about the drive assemblies and cross my eyes a bit at a metric/decimal/fraction conversion chart today.
    I'm setting up stingers & stuff for another project, so just picked up the replacement 4mm hard shaft and some 3/16" tubing to adapt some props. Every thing else I have is 4mm, so keeping them all the same.
    @Alfa- that's the setup I'm going with. Have it on two boats aready. (w/different nut & spacer)
    Wish everybody in the world would just go metric. /rant
    I'm sure the cooling can and ESC's will be here by the time the parts arrive, so I'll just skip to the end and start configuring the final Apparition setup with the 4s 2p 30c 180a/2200kv-1515/1y. Not sure on the final prop configuration, but ~45-50 MPH is my goal. I read M455, but not sure what that is or where to find it and it doesn't google well. =)
    ________
    MAGIC FLIGHT LAUNCH BOX
    • tiqueman
      • Jul 2009
      • 5866
      #77
      M445 is an Octura prop, M is its a detonged X series, 4 is 1.4 pitch and 55 is the diameter.
      • FighterCat57
        "The" Fighter Cat
        • Apr 2010
        • 3784
        #78
        They have a 2 and a 3 blade M455. @forescott, which one were you referring to?
        ________
        Maryjane
        • tiqueman
          • Jul 2009
          • 5866
          #79
          I didnt know Octura had a 3 blade M455... but it wouldnt matter how many blades. It would show though as either a M455 or a M455/3. Same size same pitch, just an added blade. As I said before, 4 means 1.4 pitch and the last 2 numbers are diameter. M is the detonged cut.
          So for example a 442, 1.4 pitch 42mm. A 642, 1.6 pitch , 42mm, etc etc. Thats how Octura works anyways. Each manufacturer has thier own unique system.
          • FighterCat57
            "The" Fighter Cat
            • Apr 2010
            • 3784
            #80
            Nice. I like this. Good numbering systems are priceless.
            I've got a nylon 2 & 3 blade assortment coming. Both of the HOTR prop assortments for testing.
            ________
            Hot Box Vaporizers
            • Alfa Spirit
              • 2183
              #81
              I think you will have nice result on 4S with Octura X442 or X642, you can try Prather S-220 too.
              My setup will be 6S and 1500kV FSD 540XL brushless motor. The cat isn' t finished yet and I have those propellers:
              Graupner K42
              Graupner K45
              Octura X442
              Octura X445
              Octura X437/3
              Octura X642
              Octura M545
              Prather S-220
              Prather S-225
              GrimRacer 40x53/3
              GrimRacer 40x57/3
              HOTR 443
              Do you think that I will find the best prop for my setup?
              • FighterCat57
                "The" Fighter Cat
                • Apr 2010
                • 3784
                #82
                Yeah, something says you'll find the right prop !
                Originally posted by Alfa Spirit View Post
                Here is exactly the shaft you need
                FYI- I have two extra of these coming in case this happens again. HOTR, $4 each.
                If anyone needs one, I can send you mine & you can order one & have it shipped to me. PM me if need be.
                SEARCH TAG: 4mm hard shaft
                ________
                IPAD GUIDE
                • forescott
                  Hopelessly Addicted to RC
                  • 3009
                  #83
                  I think I said m445. Which is 1.4 pitch and 45mm diameter. Not m455. And mine is a 2-blade.
                  • FighterCat57
                    "The" Fighter Cat
                    • Apr 2010
                    • 3784
                    #84
                    Ya said 455, but I'll let it go. Thanks for clarifying! I almost bought the 455 prop!
                    ________
                    Ferrari f2002 history
                    • forescott
                      • 3009
                      #85
                      I sure did! Sorry Ben, I'll be sure to preview before posting next time!
                      • FighterCat57
                        "The" Fighter Cat
                        • Apr 2010
                        • 3784
                        #86
                        No worries. I'm just glad you gave me a baseline setup to work from. =)
                        ________
                        New jersey medical marijuana dispensaries
                        • FighterCat57
                          "The" Fighter Cat
                          • Apr 2010
                          • 3784
                          #87
                          Originally posted by Rumdog View Post
                          The kv is too high. That is a 3s motor. You need a XL size can around 2000kv. You are pulling a LOT of amps with that setup which is why the esc is so hot.
                          Used a lower rated ESC and booo ya! 90 degree temps at basically the same speed and longer run time!
                          ________
                          Headshops
                          • FighterCat57
                            "The" Fighter Cat
                            • Apr 2010
                            • 3784
                            #88
                            Just an FYI- HOTR plans to have the twin motor Apparition in stock in a few weeks. Hobbycity will probably have some too. =)
                            I haven't quite decided if I want to go twin with this or just get one already setup as a twin.
                            For now, still planning on going with the 4s 180/2200 & M445 prop.
                            ________
                            Kingswood estate
                            • tiqueman
                              • Jul 2009
                              • 5866
                              #89
                              Set it up yourself.. Its a super fun build... then you can put your choice of real power in it.
                              • FighterCat57
                                "The" Fighter Cat
                                • Apr 2010
                                • 3784
                                #90
                                If the can fits, RUN IT!
                                This BARELY clears the hull and the hatch. I added a rubber spacer to the hull under the can to absorb any vibration and any potential wear should the can slip down. That way it won't touch the fiberglass.
                                The plan is to start with a small 36-38mm twin blade and work up from there. I don't anticipate any troubles from this setup.
                                ________
                                ONE VAPORIZER
