OLD Seaducer 37" mono OPS nitro to FE conversion build
  • Chenige
    • Jul 2011
    • 201
    Bought this boat used many years ago with a nitro 7.5 motor. Have not touched it in years. Pulled out all the nitro stuff and ready to install FE.
    Per previous input on this forum (and Offshore owner)
    Motor-Leonard 4082 X2 1600 KV
    Esc-Raider 150
    Battery-6S 5000 mAh 100C
    The first order of business is to get it water tight. I have access for free 3d printing at our local library so I am drawing up parts (Sketchup) and 3d printing.
    First thing is to fill in the access hole someone added at the front of the hatch.
  • Chenige
    • Jul 2011
    • 201
    The front modification is not quite "square". Drew it up and 3d printed the first try. Came pretty close. Added a lower portion for the cowl to insert into to hold the front end down.
    There is no nice flat lip around the entire opening so I came up with this, will 3D print it and fiberglass it into the opening on the two side ledges that are there. This should give a full perimeter, flat surface for the cowl to sit on.
    Next is the cowl itself. This is made to fit on the support ring above with the front inserted into a tab and the rear held with cowl locks. Grabbed the "bump" from the sketchup warehouse. Anyone have 3d data of different bumps/cowls?
