Dual/Twin Drive Delta Force 33 (2x540L)
    • 9481
    #76
    Very cool... I'm interested to see how 2000kv does on 5s.
    • Jesse J
      scale FE enthusiast
      • 7818
      #77
      I 2nd the paralleling of batts. Two motors drawing off 1 batt will probably result in short runs - I double mine with ONE motor... Even a pair of 4000mah would be sweet.
      Nice work and I am ready for maiden voyage!!
      "Look good doin' it"
      See the fleet
      • RCKong
        • Sep 2009
        • 1680
        #78
        Ace Hardware also has a nice selection of small SS nuts and bolts. Oh and how did you get the motor mount bolted together?
        • j.m.
          • 847
          #79
          That radio is an airplane radio, so don't hope to use it at any sanctioned events. You'll need to check the surrounding area for possible interference before you run, you don't want to bring a plane down. Those tubes are also really looong...
          I've seen nice stainless screws at Home depot. They're in the drawers.
          Jon
          • obrien008
            • Sep 2009
            • 141
            #80
            tiqueman
            I saw you were running 6s1p and that kind of convinced me that my setup should be able to run off 1p. I was really looking to save weight as this thing is gonna be very heavy. I know the weight wont really have too much impact on the speed but this thing was pretty close to failing the bathtub test at its approximate weight. It sits pretty low which should be expected I guess considering its a dual setup on only a 33, kinda wishing I would have gotten the 35'' but a little late now.
            Heres a link to the battery I got, it should be able to handle my setup
            http://hobbyking.com/hobbycity/store...idProduct=9934
            "I cant wait to see this run. " I know man me either, hopefully ill be able to get this thing in the water early next week, I got finals all next week though so we'll see
            Brushless55
            Ya im a little worried 37k unloaded rpm is more then I wanted but I wanted to go 5s, the 14L has a 1/8 shaft and I already have the flex and couplers and I couldnt find any 1/8 to .150 couplers. Not to mention my buddy is building a dual drive skunkworks cat that I gotta keep up with. If it dosent work ill just have to get 4s2p and maybe prop up a bit, but thats getting a little too far ahead. We'll just have to see how this thing runs first
            Jesse J
            2p would be nice but im saving close to 300 grams runing this 1p setup. I like to have extra run time aswell but im banking on the twins pulling a few less amps, and maybe the lower weight will help it get up on plane with less power.
            Kong
            Thanks Kong theres an ACE the next town over, I think there is a Fastenal as well, ill have to check them out
            To join the motor mounts i just cut the head off of a bolt and screwed the two together with just one bolt in the center, maybe not the best way to do it but not really sure of any other way, seems very solid. Ill prob run a carbon rod through the back of the sides to help keep the motor angle where its at.
            • tiqueman
              • Jul 2009
              • 5866
              #81
              Ive heard from 2 recent twin builds that the shed weight from an extra battery was only that, shed weight. My twin HOTR also sits LOW in the water. The water line is half way up the back deck to the hatch. You shouldnt have any problems on your 1P set up though. Just short run times. And depending on how long you stay full throttle, that can be really short. Worst Ive gotten is under 2 min. But I think its more a mah issue than anything. Ive now got some 5800s as well. Hopefully test runing this afternoon.
              • obrien008
                • Sep 2009
                • 141
                #82
                j.m.
                The 6EX is strictly air or so ive read, The 4EX can be used for surface, it has the option of low high or surface band, I got one with channel 66 surface band so im hoping it works good, got it for $130 with tx/rx batteries and 4 servos so not a bad deal if it works anyways. The tubes will be cut down, trying to see how they look as they get shorter, I kind of like the looks of the longer ones but will still def cut down a bit.
                How do you think the water pick ups will work? Too much drag?
                • Rumdog
                  • 6667
                  #83
                  In actuallity, you'll be running 1/2p per motor.
                    • 9481
                    #84
                    I'm not sure the battery will keep up, and the run time could be short..
                    • tiqueman
                      • Jul 2009
                      • 5866
                      #85
                      It will work, no doubt about it. Just short run times. I run 6S1P 5000mah to two 540 10Xls with no problems or heat at all.
                        • 9481
                        #86
                        time will tell on the first run, I hope it goes well..
                        • BakedMopar
                          No Mo Slipah
                          • Sep 2009
                          • 1743
                          #87
                          There is no doubt that your 1p setup will work. Tiqueman has proved it. Is it better probably not. I have tried it and While I don't have a GPS it was noticable. The other thing to watch is if your LVC is set high you may hit it when voltage drops during a run. Here is video to show you what i'm talking about. The setup was the same in both videos. First video is with 4s2p and the second was 4s1p. With the 1p setup its over 600 grams lighter. My suggestion for you is try it both ways and see what your boat likes. You have a very unique setup that may require something different. I definatly want to see this baby run.
                            • 9481
                            #88
                            I don't think anyone said it will not work with one battery...
                            just short runtimes, possibly LVC will kick in sooner, and time will tell how well it works on a Vee
                            • BakedMopar
                              No Mo Slipah
                              • Sep 2009
                              • 1743
                              #89
                              Basically what I'm trying to say is my experience with 1p wasn't good. I hit the cutoff on every pass. Even at 600+ grams lighter it's still slower.
                              The vids are now working.
                              • obrien008
                                • Sep 2009
                                • 141
                                #90
                                Ah that second video isnt too good, ill have to set my LVC to 3V, what was yours set to? Also aprroximate weight on 1p? Motors? Props? ESC? and what mAH/C rating on the battery? Thanks
