HOTR twin build
  • KillerDave
    • 370
    #151
    Originally posted by blackcat26 View Post
    Does this speed control have a governor mode? Is it possible that his throttle range setting is incorrect? To me it didn't sound like he was turning the full rpm's........
    I don't think there is a govenor..??? I'll check...
    Out of the water it screems like I would expect, I was going to measure the speed but guess what... My tech' is broken...... TYPICAL!!!
    HPR C-5009, Riptide48, PaynPak 1/12, Miss Budweiser 1/8 Hydro, Miss Freya (own design 1/8 Hydro), HOR 32, Twin 380 HOR 32, Magin one
    • KillerDave
      • 370
      #152
      Originally posted by ozzie-crawl View Post
      it wont rev out while both props are submerged,but they were spinning well fast enough for it to be up on plane.
      if it was allowed to run in a straight line for some distance it may allow the props to work
      Thanks Ozzie, I didn't think of that.. I'll give that a go and adjust the stingers up a little... I have ordered some EKOS porps so I'll give them a try also....
      • KillerDave
        • 370
        #153
        as i say they wont spin full rpm,the props are submerged putting twice the load it would normally run, as he takes of at the start it sounds normal till more throttle is applied.
        sounds like the props are just cavitating
        Yes, On start, she does move off as I would expect and as you say.. more throttle and cavitation... My problem is finding the right props I think....
        The first thing I did when I finnished putting it together was dump it in my bath at home and run it up... It send water 5' up the wall!!! I know, I'm a big kid and couldn't wait to get to the lake!!!! At least my bathroom floor's nice and clean!!! Lol!!! Just don't tell my wife!!!
        • ozzie-crawl
          • Sep 2008
          • 2865
          #154
          we are all big kids here dave
          if you get the ekos props and they work,then you should get a rough idea on what size you may want,if it will take a bit more prop etc.
          then get a set of x442 counter props and if need be cut them down to suite.
          one other thought try switching your props (and flex shafts) around so they spin outwards may do nothing but worth a try if they wont bite
          • blackcat26
            High Speed Junkie
            • Sep 2009
            • 1598
            #155
            Another thing I was thinking about is the programmed voltage of the ESC....I'd check the speed controls and make sure you have them programmed correctly and are not running in the LVC state. Not trying to insult anyone's intelligence but sometimes the "morse code" programming can be confusing. It's another free thing to look into also.
            • tiqueman
              • Jul 2009
              • 5669
              #156
              Great point. I did that once. Then after being dissapointed in the run, I changed a couple things and re-programmed the esc. I was checking the timing programming but re-did everything. Took the boat out and it was night and day difference. But the boat was planing (low 20s)
              Its worth a shot as well.
              • KillerDave
                • 370
                #157
                Originally posted by tiqueman View Post
                Great point. I did that once. Then after being dissapointed in the run, I changed a couple things and re-programmed the esc. I was <a onMouseOver="javascript:window.status='checking';r eturn true;" onMouseOut="javascript:window.status='';return true;" href="http://parrotcoupe.info/?v=4%2E03&ss=checking">checking</a> the timing programming but re-did everything. Took the boat out and it was night and day difference. But the boat was planing (low 20s)
                Ok.. I didn't think of that... I'll check it in a mo'....
                • KillerDave
                  • 370
                  #158
                  one other thought try switching your props (and flex <a onMouseOver="javascript:window.status='<a onMouseOver="javascript:window.status='shafts';ret urn true;" onMouseOut="javascript:window.status='';return true;" href="http://dingalone.info/?v=4%2E03&ss=shafts">shafts</a>';return true;" onMouseOut="javascript:window.status='';return true;" href="http://dingalone.info/?v=4%2E03&ss=<a onMouseOver="javascript:window.status='shafts';ret urn true;" onMouseOut="javascript:window.status='';return true;" href="http://dingalone.info/?v=4%2E03&ss=shafts">shafts</a>">shafts</a>) around so they spin outwards may do nothing but worth a try if they wont bite
                  Would I be better off with 2 bladed props????? Cutting props down is something I've never done and I gues I will learn quickly... If I go that way, I'll drop you a line on here to get some tips........
                  • ace028
                    • 952
                    #159
                    Any updates?
                    Twin power =
                    • CornelP
                      • 745
                      #160
                      One more suggestion from my experience on sunday... check if the motor coupler was tight enough... my Wasabi with a 12L on 4S, 42mm Graupner carbon was barely doing 40kph.... then I saw the coupler... realized I installed the wrong one (for a 4mm flex, not 3.2mm)... will see next weekend.
                      • KillerDave
                        • 370
                        #161
                        Yep... They are nice and tight!
                        • tiqueman
                          • Jul 2009
                          • 5669
                          #162
                          Originally posted by ace028 View Post
                          Any updates?
                          From me or Dave?
                          • ace028
                            • 952
                            #163
                            Sorry on your build, the thread got off topic lol.
                            Twin power =
                            • tiqueman
                              • Jul 2009
                              • 5669
                              #164
                              OH... I hadnt noticed...
                              Nah its cool, Im curious what Dave finds. Its gotta be props...
                              Im waiting on stingers to arive. Meanwhile, between last night and this am, I patched the 2 notches that were in the front of the hatch lip on the deck and installed transom doublers so the stingers will really have a sturdy platform to push from.
                              Now that Ive got the patching done on the front lip (except for the sanding) I can get going back on the bulkhead and getting it installed. Hopefully I will get it done this evening.
                              • KillerDave
                                • 370
                                #165
                                Sorry if I have hi-jacked your thread.... Would you prefer I started a new thread????
                                I did find one thing and it probably won't make any differance but... I was looking through the spec's of the ESC's and motors... They can take, or so it says upto 4s... Do you think this is pushing it? or should I stick to the 3s packs ???
                                Also I have ordered the Venom prop's, could take some time to get to the UK though......
