HOTR twin build
  • KillerDave
    • 370
    #136
    3S LiPo's on each motor, I was going to measure the rpm but My tach' has died...
    What else do you want to know?
    HPR C-5009, Riptide48, PaynPak 1/12, Miss Budweiser 1/8 Hydro, Miss Freya (own design 1/8 Hydro), HOR 32, Twin 380 HOR 32, Magin one
    • Alfa Spirit
      • 2131
      #137
      Are your 380 motors 3000 kV or less? Are motors hot afler a run? Did you adjust speed controlers, full power with TH trim is a the maximum?
      • tiqueman
        • Jul 2009
        • 5669
        #138
        Sounds like the motors are kinda winding out to me.. props arent hooking up. As for props, maybe try starting w/ the stock EKOS props.? Seems like the rpm is there. Even if the only props you have (matching) are the same rotation but close to the diameter you need, try them. And try x or m series on it. Those props are proven to work on cats.
        How bout some pics of the drives from the side?
        Your no load rpm should be over 31,000. I would think she should be runnin in the mid 30s easy.
        • KillerDave
          • 370
          #139
          Here are some more pic's....
          • Rumdog
            • 6453
            #140
            Definately the props. They are just cavitating and not hooking up.
            • KillerDave
              • 370
              #141
              They are 2881kv and I only ran for a short time... Not long enough to get hot....
              Sorry, Can you tell me TH trim????
              • KillerDave
                • 370
                #142
                Any sugestions on the props???
                • domwilson
                  • 4405
                  #143
                  Have you tried adjusting the prop depth? I would try raising them a little first. It's free.
                  Government Moto:
                  • blackcat26
                    High Speed Junkie
                    • Sep 2009
                    • 1598
                    #144
                    I would suggest a little space between the drive dog and stinger but I don't think thats whats slowing you down. Maybe an 1/8" or so.
                    • ozzie-crawl
                      • Sep 2008
                      • 2865
                      #145
                      looks to me like he is running a floating rear prop shaft, so no gap is needed
                      if not then yes it needs a gap.
                      i will go with my thoughts earlier on PROPS there just not hooking up,i am no prop expert but have seen the same thing when the pitch is very high.
                      if you can get a set of ekos props would be the go or as suggested any 2 props the same
                      • blackcat26
                        High Speed Junkie
                        • Sep 2009
                        • 1598
                        #146
                        Does this speed control have a governor mode? Is it possible that his throttle range setting is incorrect? To me it didn't sound like he was turning the full rpm's........
                        • ozzie-crawl
                          • Sep 2008
                          • 2865
                          #147
                          it wont rev out while both props are submerged,but they were spinning well fast enough for it to be up on plane.
                          if it was allowed to run in a straight line for some distance it may allow the props to work
                          • tiqueman
                            • Jul 2009
                            • 5669
                            #148
                            From above
                            • Alfa Spirit
                              • 2131
                              #149
                              +1 with blackcat
                              • ozzie-crawl
                                • Sep 2008
                                • 2865
                                #150
                                as i say they wont spin full rpm,the props are submerged putting twice the load it would normally run, as he takes of at the start it sounds normal till more throttle is applied.
                                sounds like the props are just cavitating
