Raptor Rigger Build
  • detox
    • 2310
    #61
    Today I hit 57.0 mph using plain Jane H-10. Low sixties is not far off.
    • raptor347
      • Jul 2007
      • 1086
      #62
      I bet the tail end came up as well.
      Now bend some pitch into that h-10.
      Brian "Snowman" Buaas
      Team Castle Creations
      NAMBA FE Chairman
      • detox
        • 2310
        #63
        Wouldn't the plain Jane S-15 work just as well as the modded H10?
        • raptor347
          • Jul 2007
          • 1086
          #64
          The S-15 is a very different prop. It takes a whole bunch of cutting to make it work on a spec boat.
          NAMBA FE Chairman
          • detox
            • 2310
            #65
            Today water was perfect (slight ripple on surface). Not using H-10 prop I hit 64.7 mph.
            • Chuck E Cheese
              • 1684
              #66
              well done!
              • Doug Smock
                • 5264
                #67
                Not much further to go now!!!!
                Well done!!
                MODEL BOAT RACER
                IMPBA President
                IMPBA 19887L CD
                NAMBA 1169
                • detox
                  • 2310
                  #68
                  Doug, Is 4s2p lipo configuration race legal? Or do you have to run 4s1p in this rigger class?
                  Yea, I thought 64.7 mph was pretty good using plain Jane prop.
                  • Doug Smock
                    • 5264
                    #69
                    1P Keith.
                    MODEL BOAT RACER
                    IMPBA President
                    IMPBA 19887L CD
                    NAMBA 1169
                    • detox
                      • 2310
                      #70
                      Oh Yea. The prop was a plain Jane ABC S-15, with evened out pitch and cup. Diameter of S-15 is actually smaller than my H-7 (46.15 vs. 47.59). My H-10 measures 44.06.
                      I wonder if the S-20 would work? Since ESC with a max of 125 amps is legal I may try.
                      • Doug Smock
                        • 5264
                        #71
                        MODEL BOAT RACER
                        IMPBA President
                        IMPBA 19887L CD
                        NAMBA 1169
                        • detox
                          • 2310
                          #72
                          Trying something different. Although not easy, the epoxied pieces were easier to break free from hull than I thought.
                          • detox
                            • 2310
                            #73
                            Boat handled great, but seemed stern heavy, so I moved COG slightly forward by moving motor, servo, and compartment devider forward 1". COG is now 4" behind sponsons. This motor configuration will also house the Nue 1415 1y.
                            My Octura .078 wire drive collet did not hold wire centered, so I ordered two of the aluminum versions from OSE. These are lighter in weight also.
                            • Darin Jordan
                              • 8332
                              #74
                              Make sure you put flats on the wire if you are going to use these couplers...
                              Darin E. Jordan - Renton, WA
                              • detox
                                • 2310
                                #75
                                Thanks Darin! Any other tricks?
